I realize these are two different operations, but I thought I could comine them into one post.
First, there is a skeleton part in my flexible assembly that I would like to have automatically open for editing (in it's own window; in the same Inventor instance) when the end user runs an iLogic rule.
Second, in a seperate rule, I need to be able to delete (not just supress) a component out of an assembly.
For both of these operations I would prefer to use the component name of the part to be opened or deleted. For deleting this is a must, but for opening the skeleton part, using file name and path will work if needed.
Thanks in advance!
Solved by loomeye. Go to Solution.
Well since I have it figured out I thought I'd post the answers to my own questions.
To open a part within an assembly (this opens a part with the same filename as the assembly + "_skeleton":
fname=ThisDoc.PathAndFileName(False)&"_Skeleton.ipt"
doc=ThisApplication.Documents.Open(fname)
To delete a part in an assembly:
compo = Component.InventorComponent("Form Tool")
compo.delete
