Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Need help with iLogic Rule to Rename drawing sheets. to input parameters
5 REPLIES 5
719 Views, 5 Replies
Need help with iLogic Rule to Rename drawing sheets. to input parameters. Can someome help me automate this? the file has 3 sheets that I want to use an input parameter thats defined earlier in the iLogic program. For some reason today I just cant figure it out????
Steve
Tags (1)
5 REPLIES 5
Curtis_Waguespack
Hi steve.markle,
Here is a quick example that gets an input from the user and applies it to the name of each sheet in the drawing.
I hope this helps.
Curtis
'get input from user
Dim sInput As String
sInput = InputBox("Enter Sheet Name", "iLogic", "Page")
'iterate through the sheets
Dim oSheet As Sheet
For Each oSheet In ThisApplication.ActiveDocument.Sheets
	'rename sheets
	oSheet.Name = sInput
Next
Here's an alternate version that prompt the user for a unique name for each sheet:
'Interate through the sheets
Dim oSheet As Sheet
	'rename sheets
Next
in reply to: Curtis_Waguespack
I know this code is not right , but this is what im trying to do
'get input from userDim sInput1 As String
sInput1 = WELDMENT_PART_NUMBER
Dim sInput2 As String
sInput2 = BLADE_BLANK_NUMBER
Dim sInput3 As String
sInput3 = HUB_PART_NUMBER
'iterate through the sheetsDim oSheet As Sheet
'rename sheets    oSheet.Name = sInput1
Next osheet
    oSheet.Name = sInput2
Next osheet
    oSheet.Name = sInput3
Thanks so much for your help!!!
Steve
Curtis_Waguespack
Hi steve.markle,
There might be a more concise way to do this, but this example should work for you.
I hope this helps.
Curtis
sInput1 = "Cover Sheet"
sInput2 = "General Arangement"
sInput3 = "Details"
Dim lPos As Long
Dim lLen As Long
Dim sShName As String
Dim sShNum As String
Dim oSheet As Sheet
   lPos = InStr(oSheet.Name, ":") 'position of the colon
   lLen = Len(oSheet.Name) 'length of sheet name
   sShName = Left(oSheet.Name, lPos -1) 'string left of the colon
   sShNum = Right(oSheet.Name, lLen -lPos ) 'string right of the colon
          If sShNum = 1 Then
          ElseIf sShNum = 2 Then
          ElseIf sShNum = 3 Then
          End If
Next
EXCELLENT!!! Worked perfectly!!
Steve
EXCELLENT!!!
Worked perfectly!!
Steve
