Is there a way of monitoring for parameter changes and then running subroutines or other things based on the change, like:
If HouseColor *changes* Then Call PaintHouse() End IF
I'm looking to do this for a multi-value string parameter thats in a form as a combo box.
Preferrably I would like to see this done without any external files as I am trying to create a .ipt that contains everything for the thing I'm working on.
Is this possible?
I've written a blog post which should be of help:
http://adndevblog.typepad.com/manufacturing/2014/11/get-notified-about-parameter-change.html
Cheers,
Thanks for the input, what you did in the blog post looks great, but my rule is very complex with 20+ parameters, so I dont think I can use your method.
Is it possible to use ModelingEvents.OnParameterChange to monitor specific parameters, or is it the global "Any parameter change" check?
Thanks!
It is global, but there you'll get the parameter that changed as an input parameter:
Event OnParameterChange(DocumentObject As _Document, Parameter As Parameter, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum)
