Would anyone have examples of how to modify ThreadInfo using the api.
Currently trying to use the code below to create a new ThreadInfo Object and assign it to the feature... but whenever the oClass is "" (zero length string) the the CreateStandardThreadInfo fails.
oThreadFeatures.Item(ThreadName).ThreadInfo = NewThreadInfo(oInternal, oRightHanded, oThreadType, oThreadDesignation, oClass)
Public Function NewThreadInfo(ByVal oInternal As Boolean, ByVal oRightHanded As Boolean, ByVal oThreadType As String, ByVal oThreadDesignation As String, ByVal oClass As String) As
ThreadInfo
Try
NewThreadInfo = oThreadFeatures.CreateStandardThreadInfo(oInternal, oRightHanded, oThreadType, oThreadDesignation, oClass)
Catch ex As
Exception
MessageBox
.Show(ex.Message)
End
Try
End
Function
Below is a VBA code sample from API document:
Sub EditThread() Dim oDoc As PartDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As PartComponentDefinition Set oDef = oDoc.ComponentDefinition ' Create a new thread info object containing the thread data Dim oNewThreadInfo As StandardThreadInfo Set oNewThreadInfo = oDef.Features.ThreadFeatures.CreateStandardThreadInfo(False, True, "ISO Metric Profile", "M20x2.5", "6g") ' Get the first thread feature Dim oThread As ThreadFeature Set oThread = oDef.Features.ThreadFeatures.Item(1) ' Edit the thread feature oThread.ThreadInfo = oNewThreadInfo End Sub
The Class argument is required, and below is the description for it:
Class : Input String that defines the thread class. For example a valid class for an inch internal thread is 2B. A valid class for a metric external thread is 6g.
Hope this helps.
