Modify ThreadInfo using the API
1 REPLY 1
guilloryt
393 Views, 1 Reply
Would anyone have examples of how to modify ThreadInfo using the api.
Currently trying to use the code below to create a new ThreadInfo Object and assign it to the feature... but whenever the oClass is "" (zero length string)  the the CreateStandardThreadInfo fails.
oThreadFeatures.Item(ThreadName).ThreadInfo = NewThreadInfo(oInternal, oRightHanded, oThreadType, oThreadDesignation, oClass)
Public Function NewThreadInfo(ByVal oInternal As Boolean, ByVal oRightHanded As Boolean, ByVal oThreadType As String, ByVal oThreadDesignation As String, ByVal oClass As String) As
ThreadInfo
Try
NewThreadInfo = oThreadFeatures.CreateStandardThreadInfo(oInternal, oRightHanded, oThreadType, oThreadDesignation, oClass)
Catch ex As
Exception
MessageBox
.Show(ex.Message)
End
Try
End
Function
1 REPLY 1
YuhanZhang
in reply to: guilloryt
Below is a VBA code sample from API document:
Sub EditThread()
   Dim oDoc As PartDocument
   Set oDoc = ThisApplication.ActiveDocument
   Dim oDef As PartComponentDefinition
   Set oDef = oDoc.ComponentDefinition
   ' Create a new thread info object containing the thread data
   Dim oNewThreadInfo As StandardThreadInfo
   Set oNewThreadInfo = oDef.Features.ThreadFeatures.CreateStandardThreadInfo(False, True, "ISO Metric Profile", "M20x2.5", "6g")
   ' Get the first thread feature
   Dim oThread As ThreadFeature
   Set oThread = oDef.Features.ThreadFeatures.Item(1)
   ' Edit the thread feature
   oThread.ThreadInfo = oNewThreadInfo
End Sub
The Class argument is required, and below is the description for it:
Class : Input String that defines the thread class. For example a valid class for an inch internal thread is 2B. A valid class for a metric external thread is 6g.
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
