Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Modify referenced model by iLogic
7 REPLIES 7
Message 1 of 8
TONELLAL
6172 Views, 7 Replies
I try to modify on a drawing the 3d model, using iLogic (same thing as Inventor "Replace model reference" command). Do you know if it is possible ?
7 REPLIES 7
Message 2 of 8
TONELLAL
in reply to: TONELLAL
So... nobody need to replace the 3d model from a drawing ?
Message 3 of 8
xiaodong_liang
This will need the Advanced API of iLogic: ThisDoc.Document.
 e.g. the code below replace the first file of the drawing to a new part. Hope it helps.
 doc = ThisDoc.Document
 Dim oFD As FileDescriptor
 oFD = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
 oFD.ReplaceReference("c:\NewPart.ipt")
 doc.Update()
Message 4 of 8
TONELLAL
in reply to: xiaodong_liang
Thanks !
This is exactly what I need !
Message 5 of 8
Xiaodong,
How would I change the following code to include a second .ipt in the replace reference routine?
I have a part 485000-001 and 485000-002. I can successfully replace the reference of the 485000-001 but, cannot replace the 485000-002.
Could you assist with this?
Sub SAVEDETAIL (ByVal TemplateDrawing As String, ByVal PLAINPN As String, ByVal PNWSUFFIX As String, ByVal PTASSYPN As String, ByVal filePath As String)
      DESTINATIONDOC = ThisApplication.DOCUMENTS.Open(TemplateDrawing, False)
      DESTINATIONDOC.SAVEAS(filePath & PLAINPN & ".idw", False)
      Dim STRNEWREFNAME As String
      Dim OREFFILE As FILEDESCRIPTOR
      For Each OREFFILE In DESTINATIONDOC.FILE.REFERENCEDFILEDESCRIPTORS
            Dim OORIGREFNAME As String
	   OORIGREFNAME = OREFFILE.FULLFILENAME
            If OORIGREFNAME.EndsWith(".ipt") Then
		STRNEWREFNAME = filePath & PNWSUFFIX & ".ipt"
		OREFFILE.REPLACEREFERENCE(STRNEWREFNAME)
	   ElseIf OORIGREFNAME.EndsWith(".iam") Then
		STRNEWREFNAME = filePath & PTASSYPN & ".iam"
	   End If
      Exit For
      Next
      DESTINATIONDOC.Update()
      DESTINATIONDOC.Save
      DESTINATIONDOC.Close
End Sub
Message 6 of 8
itults
I am after some code that reads the .idw filename and uses the Replace Model Reference routine to replace the first component in the .idw with an .ipt or .iam that is in exactly the same folder.
Message 7 of 8
Pavel_JDK
in reply to: itults
I was trying to make ilogic rule for changes of references. For Your request You can try function "idw reference" in enclosed rule "change_reference.iLogicVb". It's possible to run from model or drawing and it changes reference in idw file with same name model (ipt or iam or ipn) in the same folder. If there is second reference ipn model, it is also changed.
You can use the rule also for changes of ipn, ipt and other references in many ways.
Regards
Pavel
Here shoud be video. If not, You can see it on my dashboard...
https://autode.sk/2WfUKML
Message 8 of 8
Pavel_JDK
in reply to: Pavel_JDK
Another videos with example of using the rule change_reference:
https://autode.sk/30hbS5R
https://autode.sk/3fAanpH
