I'm trying to automate the creation of a new subassembly and demote a circular occurrence pattern to it. I can do it, manually, without incident but the VBA macro kicks out an error. I set SilentOperation = True, but VBA still kicks out the error and my pattern doesn't get demoted.
Here's the code. I'd appreciate any help.
Public Function TESTDemoteDeck() Call InitializeMainObjects Dim oNewSubAssy As AssemblyDocument Set oNewSubAssy = oApp.Documents.Add(kAssemblyDocumentObject, , False) Dim oMat As Matrix Set oMat = ThisApplication.TransientGeometry.CreateMatrix Dim oSubAssyOcc As ComponentOccurrence Set oSubAssyOcc = oAsmCompDef.Occurrences.AddByComponentDefinition(oNewSubAssy.ComponentDefinition, oMat) Dim oPane As BrowserPane Set oPane = oDoc.BrowserPanes.Item("Model") Dim oSubAssyNode As BrowserNode Set oSubAssyNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc) ' Get the last visible child node under the sub-assembly occurrence Dim oTargetNode As BrowserNode Dim i As Integer, j As Integer For i = oSubAssyNode.BrowserNodes.Count To 1 Step -1 If oSubAssyNode.BrowserNodes.Item(i).Visible Then Set oTargetNode = oSubAssyNode.BrowserNodes.Item(i) Exit For End If Next Dim oSourceNode As BrowserNode Set oPattern = oAsmCompDef.OccurrencePatterns.Item("PatternName") Set oSourceNode = oPane.GetBrowserNodeFromObject(oPattern) oApp.SilentOperation = True On Error GoTo CheckError '##ERROR FROM THE LINE BELOW THIS Call oPane.Reorder(oTargetNode, False, oSourceNode) oApp.SilentOperation = False CheckError: Debug.Print "!!!!Run-time Error!!!!" Debug.Print " Err.Number = " & Err.Number Debug.Print " Err.Descri = " & Err.Description Resume Next End Function
Most of it is taken directly from the code example in the API Help reference
Oh, here's the error. I believe it's just a generic automation runtime error.
Err.Number = -2147467259
Err.Descri = Method 'Reorder' of object 'BrowserPaneObject' failed
Solved by MjDeck. Go to Solution.
Although you can use BrowserPane.Reorder to demote a component into a subassembly, it doesn't work for a component pattern. We should be able to make it work in a future version.
