I know this is an ancient topic but I have been unable to find a suitable answer.
My problem is that I need to show the physical property Mass in my Vault Basic.
The only way I know to do this is to create a custom property that I could import later in Vault.
When trying to create "Weight" (in order not to have the same name) as a custom property of the physical property Mass I find some inconveniences:
- There is too much precision, I have 6 decimal numbers after the point.
- The result is in gramms
I define Custom property, as a text property, =<Mass> kg
So, is there any way that I can obtain this property as:
0.4 kg instead of
432.562014 kg ?
Thank you very much in advanced
Solved by cadmanagershat. Go to Solution.
Hello again,
I had forgotten that I need to do this for .ipt and .iam.
For parts I can create the custom property, despite its customization, but I have no idea how to do it with an assembly, because Inventor doesn't recognise <Mass> as property.
Thanks again
Jorge
Not really sure if this will help you but I have this piece of code which changes the amount of decimal places based on the total weight.
Dim mass As Decimal mass = iProperties.Mass Dim massString As String Select Case mass Case < 1 massString = CStr(Round(mass, 2, MidpointRounding.AwayFromZero))& " kg" Case 1 To 10 massString = CStr(Round(mass, 1, MidpointRounding.AwayFromZero))& " kg" Case > 10 massString = CStr(Round(mass, 0, MidpointRounding.AwayFromZero))& " kg" End Select iProperties.Value("Custom", "Mymass")= massString
I can then populate the drawing border with the custom property. Works in part and assembly files also.
