Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Macros / VBA Editor button not working
11 REPLIES 11
Message 1 of 12
ADNpati
8741 Views, 11 Replies
Inventor 2014 (came with FDS2014)VBA Editor /MAcros button is not working.
Load VBA on start-up is not available in Application Options.
Can somebody point out me in right direction.
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
11 REPLIES 11
Message 2 of 12
ADNpati
in reply to: ADNpati
Fuound Solution Here
  1. Install VBA7 (Vba71033.MSI installer File) English language pack from physical installation Drive (USB drive from Autodesk) to your computer.
  2. Restart Inventor
Mechanical Engineer
Message 3 of 12
miechh
It doesn't solve the problem of the option "Load VBA on Start-up" which is missing, but is still mentioned in the (on-line!) help. Is this option removed from Inventor 2014?
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
Message 4 of 12
mukhi05
Download the Microsoft Visual Basic for Applications (VBA) Module for all AutoCAD products
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/download-microsoft-vi...
follow the instruction
Run Vba71_1031.msi
Message 5 of 12
ADNpati
in reply to: miechh
OPtion is not available in 2014 Inventor. Henace VBA is Auto-loaded component.
Please follow above solution and will able to load vba.
There are some issues with MS Office 2013, vba doesn't load.
For this, we need to install VB7 from setupfiles hard dirve. 3Rdparty/x64/VBA
Mechanical Engineer
Message 6 of 12
DamienWessling
ADNpati, your solution resolved this issue for my site. We have 18 seats of Inventor 2015 Pro without functioning VBA until today. Many thanks.
Vault Admin & Systems A/P.
Message 7 of 12
ADNpati
in reply to: DamienWessling
No worries mate.
Mechanical Engineer
Message 8 of 12
guru.r
in reply to: mukhi05
Hi
The link is broken. Can you report please
Message 9 of 12
qall
Is there any reference from where I can download this VBA7.msi file?
Using INV2014 and have same problem that VBA does not launch when I click on the icon.
Thanks!
Message 10 of 12
tomesz1987
in reply to: qall
I've same problem as ADNpati described with Inventor 2018 x64 build 112.
I found a few install files for VBA. Which one do I need to install?
See pic. attached.
Regards
Tomek
Message 11 of 12
DamienWessling
in reply to: tomesz1987
Hi Tomek,
Right click on the first Vba71.msi (your extensions are hidden) and select Install. The variants listed under are the region/language specific files which will are used once the installation commences.
Cheers,
Damien  Wessling.
Message 12 of 12
qall
See pic. attached.
Regards
Tomek
I still have problem with this when I install by clicking on the VBA file nothing happens after the process commences.
