MACRO PDF with revision number if exists in the drawing
7 REPLIES 7
Message 1 of 8
1023 Views, 7 Replies
I have a macro for exporting my drawings to PDF.
But I want improve by adding the revision number only if the drawing has a revision number.
Actually (an extract of my macro with VBA)
'Set filename as original document filename.
Dim FileName As String
FileName = oDocument.FullFileName
Dim Temp() As String
Temp = Split(FileName, "\")
FileName = Left(Temp(UBound(Temp)), Len(Temp(UBound(Temp))) - 4)
'Set the destination to save files.
oDataMedium.FileName = "C:\Path...\" & FileName & ".pdf"
I wish this result :
If no revision : PartNumber.pdf
If revision : PartNumber_RevisionNumber.pdf
Thanks you,
7 REPLIES 7
Message 2 of 8
Ktomberlin
This Should help.
Dim oRevNum As String
oRevNum
= iProperties.Value("Project", "Revision Number") Dim oFileName As String
oFileName
= ThisDoc.FileName(False) If oRevNum >= 1 Then oDataMedium.FileName = "C:\Path...\" & oFileName & "_" & oRevNum & ".pdf" Else oDataMedium.FileName = "C:\Path...\" & oFileName & ".pdf" End If
Message 3 of 8
in reply to: Ktomberlin
Thanks, but I think that working for iLogic, but don't working wih VBA.
How to get (Revision Number) with VBA (I'm a rookie with VBA)
Dim RevNum As (String ?)
RevNum = (?)
Message 4 of 8
Ktomberlin
Sorry, forgot i had to change that in VB
Dim oRevNum As String = GetPropertyValue(ThisDoc, "Inventor Summary Information", "Revision Number")
Message 5 of 8
The "Revision Number" don't work.
If I use iLogic and not "VBA", because it's working better.
How to add a button in the ribbon ?
Like this : (with custom icon)
http://modthemachine.typepad.com/my_weblog/2008/11/creating-buttons-for-vba-macros.html
Message 6 of 8
Ktomberlin
This works now for sure.
Dim oDocRevision As Property
Dim Revision As String
Set oDocRevision = oDocument.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
               If oDocRevision.Value = 0 Then
                    oDataMedium.FileName = "C:\Temp\" & FileName & ".pdf"
                Else
                    Revision = "_Rev-" + CStr(oDocRevision.Value)
                    oDataMedium.FileName = "C:\Temp\" & FileName & Revision & ".pdf"
                End If
'Publish document.
Call PDFAddin.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Message 7 of 8
Great, thank you very much.
Just a little correction.
I replaced :
 by
If oDocRevision.Value = "" Then
Message 8 of 8
Ktomberlin
You could change that to Null or 0 for the same result.
