Hi
I have one problem in this macro this macrofor drawing exporting to PDF.
How to save the pdf files in same location(Converting Drawing file location) and same number(Drawing file number).
Second one is in my inventor window I opened 20 files of drawings and how to set the macro for export to pdf all the 20 files in once.
Please help me.
Public Sub PublishPDF()
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'Set the destination file name
oDataMedium.FileName = "c:\temp\test.pdf"
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Thanks in advance
Thanks & Regards,
LINUS KOTTE
Linus,
What you want to do is create a sub routine based on your sample that takes parameters such as PdfFilename and TargetFolder.
For example:
Public Sub CreatePDF(Byval TargetFolder as string, Byval PdfFileName as string)
End Sub
Create a list of fullfilenames for all drawings that are loaded in inventor.
Loop through the list calling your new sub routine with the filenames..
Hi linuskotte,
The workflow Gruff suggested is a kind of code like below:
Public Sub batchPDF() Dim oEachDoc As Document For Each oEachDoc In ThisApplication.Documents ' if this is a drawing document If oEachDoc.DocumentType = kDrawingDocumentObject Then Call PublishPDF(oEachDoc) End If Next End Sub Public Sub PublishPDF(doc As DrawingDocument) ' Get the PDF translator Add-In. Dim PDFAddIn As TranslatorAddIn Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document 'Set oDocument = ThisApplication.ActiveDocument Set oDocument = doc Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Options for drawings... oOptions.Value("All_Color_AS_Black") = 0 'oOptions.Value("Remove_Line_Weights") = 0 'oOptions.Value("Vector_Resolution") = 400 'oOptions.Value("Sheet_Range") = kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name 'oDataMedium.filename = "c:\temp\test.pdf" oDataMedium.filename = "c:\temp\test" & doc.DisplayName & ".pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End Sub
As Inventor SaveAs supports PDF why not use that instead of the translator addin?
Thnkyou Liang for your reply .
Here one more quetion is how to save all pdf files into the active project folder.
Thanks & Regards,
LINUS KOTTE
Hi LINUS KOTTE,
Sorry, I am not clear on you question. The workflow of translator addin will require the save path of the final file. i.e. for PDF, it is the code I marked in black. so you just need to specify the path where you wanted to save.
As to project path, you can get it by DesignProject.WorkspacePath.
Public Sub PublishPDF() ' Get the PDF translator Add-In. Dim PDFAddIn As TranslatorAddIn Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document Set oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Options for drawings... oOptions.Value("All_Color_AS_Black") = 0 'oOptions.Value("Remove_Line_Weights") = 0 'oOptions.Value("Vector_Resolution") = 400 'oOptions.Value("Sheet_Range") = kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name oDataMedium.FileName = "c:\temp\test.pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End Sub
