I'm not smart enough to figure this out so I'm hoping someone can write this up for me 🙂
Basically I have a few custom iProps in IDW's that I need to delete. I know I can do it manually but it's tiresome on hundreds of drawings.
I'm thinking something like :-
If Custom iProperty "Not Needed" exists then delete it Else Next
If Custom iProperty "Also Not Needed" exists then delete it Else Next
And so on an so forth.
The list of iProps to delet is finite and I am comfortable copy/paste and change text in a macro (or iLogic) to replicate your working code to delete further iProps.
Thanks in advance.
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Solved by saseendrankombath. Go to Solution.
Public Sub Del_Custom_iProp() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oCustomset As PropertySet Set oCustomset = oDoc.PropertySets.Item("User Defined Properties") Dim oProp As Property For Each oProp In oCustomset If oProp.Name = "Not Needed" Or oProp.Name = "Also Not Needed" Then oProp.Delete End If Next End Sub
please can anyone write a code for me, for this please, anyone, if i don't write it within a month i will fail in my test
