Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Looking for someone to write me some code
3 REPLIES 3
brendan.henderson
375 Views, 3 Replies
I'm not smart enough to figure this out so I'm hoping someone can write this up for me 🙂
Basically I have a few custom iProps in IDW's that I need to delete. I know I can do it manually but it's tiresome on hundreds of drawings.
I'm thinking something like :-
If Custom iProperty "Not Needed" exists then delete it Else Next
If Custom iProperty "Also Not Needed" exists then delete it Else Next
And so on an so forth.
The list of iProps to delet is finite and I am comfortable copy/paste and change text in a macro (or iLogic) to replicate your working code to delete further iProps.
Thanks in advance.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
3 REPLIES 3
Public Sub Del_Custom_iProp()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCustomset As PropertySet
    Set oCustomset = oDoc.PropertySets.Item("User Defined Properties")
    Dim oProp As Property
    For Each oProp In oCustomset
        If oProp.Name = "Not Needed" Or oProp.Name = "Also Not Needed" Then
            oProp.Delete
        End If
    Next
End Sub
Thank you
Brendan Henderson
CAD Manager
please can anyone write a code for me, for this please, anyone, if i don't write it within a month i will fail in my test
