Loading Files with same in Inventor session
3 REPLIES 3
santoshr0114
259 Views, 3 Replies
Is there a way in Inventor which restricts the user from loading a file having same name.
Scenario:
I have one file in a location D:\Autodesk\Location1\Part1.ipt and second file in D:\Autodesk\Location2\Part1.ipt. (The Geometry and properties might be same or might not be same).
I open the first file Part1 from D:\Autodesk\Location1\Part1.ipt. Now this first file is loaded in Inventor session.
Now if i try to open second file Part1 from D:\Autodesk\Location2\Part1.ipt inventor should not allow me to open. (By Default Inventor allows, as the Location is different)
This is the case i want Inventor to handle...
How can i acheive this.?
Regards
Santosh
3 REPLIES 3
santoshr0114
in reply to: santoshr0114
Can anybody Help me out...?
Regards
Santosh
matt_jlt
You will need to have an addin running that monitors the application events.
Brian Ekins post on his blog have a great example on how to use events
http://modthemachine.typepad.com/my_weblog/2013/07/add-in-with-event-example-to-replace-auto-run-mac...
Below is a rough example of what you need to do (please note I just threw this together and could have problems, it's just a guide)
Private Sub m_ApplicationEvents_OnOpenDocument( DocumentObject As Document, FullDocumentName As String, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum )
If BeforeOrAfter = EventTimingEnum.kBefore Then
        Try
            Dim strNewDoc As String = System.IO.Path.GetFileNameWithoutExtension(FullDocumentName)
            Dim oDoc As Document
            For Each oDoc In ThisApplication.Documents
                 If System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) = strNewDoc Then
                       ' Close the document
                       DocumentObject.Close ' Havn't checked if .close is the correct call
                       Exit Sub
                 End If
            Next
         Catch Ex As Exception
            messagebox.show(ex.message)
         End Try
End If
santoshr0114
in reply to: matt_jlt
This is what i am currently doing.i.e., Monitoring with an addin.
Now we cannot use adding to monitor. Thats why we want to change.
I have been listening to ApplicationEvents.OneOpenDocument and AssemblyEvents.NewOccurrence. But we cannot veto the operattion.
As per API documentation HandlingCode will be ignored for these events.
Regards
Santosh
