I have a annoying problem that i am looking for some thoughts on.
I have a spreadheet linked to a model. This spreadsheet is a depository for parameters which are filled in or selected by my users.
The model itself is controlled by some ilogic rules which use these spreadsheet parameter values to perform certain tasks, suppress/activate components etc.
Now to the annoyance
With the model opened I choose to edit the spreadsheet (select the spreadsheet in the model tree)
Parameters are updated in the spreadsheet and when this is saved the ilogic rules are triggered.
Model updates perfectly.
However I get this excel message asking if I want to save the spreadsheet.
Thats the problem. I send nothing back from Inventor to the spreadsheet so it really has not changed. I answer no to the question and everything is fine.
Any ideas why i would get this message?
I have countless models set up with linked spreadsheets and this behaviour only appears on one or two.
I would like to get rid of this message it is confusing to my users.
I tried setting DisplayAlerts to False in the spreadsheet to no avail
Any thoughts or ideas how to overcome this would be appreciated
Can you reproduce the behaviour with some non-confidential small model as well that you could upload for us to play with?
Cheers,
Adam,thanks for the reply and offer to look at this behaviour. I have attached a small assembly and the spreadsheet.
Try opening the asm and then editing the spreadsheet select a new value for named cell x11partnumber from the drop down validation list on the first worksheet. Saving the excel triggers the rule. That will give the message asking if the excel should be saved.
Model updates correctly. The message to save the eccel is annoying and strange.
I am using Inventor 2009 + excel 2000
