Hello frineds.
How I can link parameter from sketch1 in drawiing to an user parameter?
Solved by MegaJerk. Go to Solution.
Pozdrav,
User parameter is parameter that you creating. You can export parameters and import same parameters in another drawings. Link them with iLogic rule.
Parameter("model parameters", "your parameter") =user parameter
Sretno
Pozdrav,
We have a misunderstanding. I don't need to import parameters from another drawing. I just have few parameters created by: Manage-Parameters-Add Numeric. Now I just need to link that parameters with some dimensions in sketch. I know that it works in sketch of part but I don't know is it posible to do with sketch of drawing?
Hvala.
Danijel
I'm using sketch in drawing very rare, i didn't try but i bet you could link parameters in above described. You can PM me if you want.
I believe that the post over on Being Inventive will guide you in the right direction : Control Sketched Symbol and Title Block via drawing parameters using Ilogic
Side note: Because Autodesk has not yet exposed the dimensions for drawing views / sketches for proper, there is currently no way to rename those dimensions through your Inventor client. You might be able to change the names via the API, but I have not had the time to test this theory out. The more complex your sketches get, the more work you're going to have to put in into making sure that those hidden model parameters are the ones that you'd like to access / tie to a drawing parameter.
I hope that this helps.
- The Jerk
Thanks MegaJerk
I tried your solution and for now it is only accepted. Thanks for the help friends.
