Hi all,
Is it possible to use the 'Link Levels of Detail' command via the API ?
I can activate the command by using the CommandManager
oContDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_LinkLODsCmd") oContDef.Execute
But the command then requires a UI selection - I want to select the iLogic LOD.
I've tried using the CommandManager.PostPrivateEvent but to no avail
Does anybody know if this is possible?
Tom
Solved by thomaskennedy. Go to Solution.
On second thoughts I can just iterate through the assembly and set each occ to the iLogic LOD.
Tom I have some code for this I'll email you
@chris.atherton wrote:Tom I have some code for this I'll email you
You should post it here, so that others can learn if they have the same question.
