Link Levels of Detail via API
3 REPLIES 3
thomaskennedy
668 Views, 3 Replies
Hi all,
Is it possible to use the 'Link Levels of Detail' command via the API ?
I can activate the command by using the CommandManager
oContDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_LinkLODsCmd")
oContDef.Execute
But the command then requires a UI selection - I want to select the iLogic LOD.
I've tried using the CommandManager.PostPrivateEvent but to no avail
Does anybody know if this is possible?
Tom
3 REPLIES 3
On second thoughts I can just iterate through the assembly and set each occ to the iLogic LOD.
Tom I have some code for this I'll email you
Chris Atherton
IEng MIMechE BEng Hons
Design Automation Services Manager | Symetri
https://uk.linkedin.com/in/chrissoathe
MegaJerk
in reply to: ChrisAtherton
You should post it here, so that others can learn if they have the same question.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
