Inventor Customization
Member
0 Kudos
Post 1 of 5
Level of Detail macro
679 Views, 4 Replies
04-18-2011 01:57 AM
Hi
Can anyone help by providing a VBA script to to change the Level of display for an assembly AND ALL its sub-asseemblies automatically to an LOD that I called ilogic when opening the file.
I am running Inventor 2011 and I need this as it is creating some problems with the ilogic rules when they run....
Thanks for your help
Valued Contributor
0 Kudos
Post 2 of 5
Re: Level of Detail macro
04-18-2011 09:49 AM in reply to: NEGMEC
Here is some .NET code. You will have to convert it to VBA. LOD works kind of funny from what I can tell. You must first set the LOD of the top assy and all sub-assy's and save the model. All my attempts to set the individual sub-assy's LOD result in an Inventor application crash.
        Dim oMyDoc As Inventor.AssemblyDocument
        oMyDoc = invApp.ActiveDocument
        ' Set the Level Of Detail...
        Dim oRepMgr As Inventor.RepresentationsManager
        oRepMgr = oMyDoc.ComponentDefinition.RepresentationsManager
        Dim oMasterLOD As Inventor.LevelOfDetailRepresentation
        oMasterLOD = oRepMgr.LevelOfDetailRepresentations.Item('iLogic")
        oMasterLOD.Activate()
Valued Contributor
0 Kudos
Post 3 of 5
04-18-2011 09:52 AM in reply to: herrwolf1
Also, here is an iLogic rule that I place in the sub assemblies that require component suppression
Sub SetLOD(ByVal myLOD As String)
	ThisApplication = InventorVb.Application
	oMyDoc = ThisDoc.ModelDocument
	' Set the LOD to Master
	Dim oRepMgr As RepresentationsManager
    Dim oMasterLOD As LevelOfDetailRepresentation
    oMasterLOD = oRepMgr.LevelOfDetailRepresentations.Item(myLOD)
	RuleParametersOutput() ' use this before DocumentUpdate
	InventorVb.DocumentUpdate() ' Update now
End Sub
Member
0 Kudos
Post 4 of 5
04-24-2011 03:37 PM in reply to: NEGMEC
Thanks herrwolf1
do you know how to change the LOD using i-logic?
Valued Mentor
187 Kudos
Post 5 of 5
04-25-2011 09:32 AM in reply to: NEGMEC
For iLogic Code to change the LoD I use the following (which is of course still VB , but it runs inside of an ilogic rule!)
'''We need to make sure the LOD is set correctly :
'''Side note
'''Public Enum LevelOfDetailEnum
''' kMasterLevelOfDetail = 56065
'''kAllComponentsSuppressedLevelOfDetail = 56066
'''kAllPartsSuppressedLevelOfDetail = 56067
'''kAllContentSuppressedLevelOfDetail = 56068
'''kSandboxLevelOfDetail = 56069
'''kTransientLevelOfDetail = 56070
'''kSubstituteLevelOfDetail = 56071
'''kCustomLevelOfDetail = 56072
'''kLastActiveLevelOfDetail = 56073
'''End Enum
Dim doc as AssemblyDocument = ThisDoc.Document
If doc.ComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation.LevelOfDetail <> 56072 'LevelOfDetailEnum.kMasterLevelOfDetail Then
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("ilogic")
oLOD.Activate(True)
That will change the main level of detail, but I'm sure you could throw it into the rules of your subassemblies and get similar results (maybe :smileysad: ). Use triggers to make it run on document open!
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Post to the Community
New Post
