Layer Visibility On Different Sheets
I am trying to control the layer visibility on different sheets of the same drawing but have not quite figured it out yet.
We add a DXF sheet to drawings with flat pattern views to export to DXF for our laser.  I wrote a VBA macro that adds the sheet, copies the flat pattern view and removes the dimensions to clean it up before creating the DXF.  I am having a problem turning off the visibility of the bend lines on JUST the DXF sheet.  I can turn bend lines and hidden lines off with this:
'Turn off bend lines and hidden lines
For Each oView In oSheet.DrawingViews
    'Set the layers collection
    Set oLayers = oDrawingDoc.StylesManager.Layers
    'Turn off all bend lines and hidden lines
    For Each oLayer In oLayers
        If Not InStr(oLayer.Name, "Bend Centerline") = 0 Or Not InStr(oLayer.Name, "Hidden") = 0 Then
            oLayer.Visible = False
        Else
    Next
Next
 but it turns them off on all sheets.  I want to only turn them off on the DXF sheet.  How would this be done?
Accepted solutions (3)
jdkriek
Here's how I usually turn off hidden for a specific sheet.
Sub TurnOffHidden()
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
'Define which sheet
Set oSheet = oDrawingDoc.Sheets.Item(1)
Dim oView As DrawingView
        oView.ViewStyle = kHiddenLineRemovedDrawingViewStyle
    Next
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Thanks, that is half the problem.  Any ideas for the bend lines?
jdkriek
I usually set those options when I export the DXF
Dim oDataIO As DataIO
Set oDataIO = oPart.ComponentDefinition.DataIO
'Set ACAD Version, Outer Profile, and hide bend lines
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=Outer&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up;IV_ARC_CENTERS"
'Create Save Path
Dim SavePath As String
SavePath = "C:\DXF OUT\" & sPartNum.Value & ".dxf"
'Create the DXF file.
oDataIO.WriteDataToFile sOut, SavePath
Jonathan D. Kriek
I usually do it that way too but we like to have a separate sheet that shows the flat view exactly as you would see it in the DXF.  Right now we just right click on them and turn off.
jdkriek
This is as far as I got.
It's interesting to me that once I found the bendline, I wasn't able to select it for DrawingEntityVisibilityCtxCmd via the Command Manager which is the command that is used when you right-click and hide the line through the UI.
Sub NixHiddenBend()
Dim oSheet As Sheet
'Define which sheet
        'If it's a flatpattern view
        If oView.IsFlatPatternView = True Then
            Dim oViewCurves As DrawingCurvesEnumerator
            Set oViewCurves = oView.DrawingCurves()
            Dim oBendLine As DrawingCurve
                'Find all the lines
                For count = 1 To oViewCurves.count
                    Set oBendLine = oViewCurves.Item(count)
                    'If it's a bendline
                    If oBendLine.EdgeType = kBendDownEdge Or oBendLine.EdgeType = kBendUpEdge Then
                        MsgBox ("Found you pesky bendline")
                Next
    Next
End Sub
Jonathan D. Kriek
xiaodong_liang
Autodesk Support
Autodesk Support
Hi
Sub NixHiddenBend()
Dim oSel As SelectSet
Set oSel = oDrawingDoc.SelectSet
oSel.Clear
Dim oSheet As Sheet
'Define which sheet
                'Find all the lines
                For Count = 1 To oViewCurves.Count
                    Set oBendLine = oViewCurves.Item(Count)
                    'If it's a bendline
                        'MsgBox ("Found you pesky bendline")
                        Dim oSeg As DrawingCurveSegment
                        For Each oSeg In oBendLine.Segments
                            oSel.Select oSeg
                        Next
                Next
    Next
     ThisApplication.CommandManager.ControlDefinitions("DrawingEntityVisibilityCtxCmd").Execute
End Sub
