Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
kDrawingDocumentObject Usage failure
3 REPLIES 3
Ktomberlin
1113 Views, 3 Replies
Due to a MRP issue. we have to now add a new custom property to some files for drawing purposes.  This code works if run on a drawing but posts an error on parts or assemblies,
ThisDrawing: This document "P054002-P010025-010-125-050-1-W-1" is not a drawing.
Anyone have the change i need to make this work for all docment types?
'Inputing New DetailViewName
doc = ThisDoc.ModelDocument
'doc = ThisDoc.Document
Dim MyDetailViewName As String
Dim CurrentPN As String
If doc.DocumentType = kDrawingDocumentObject Then
	Goto Drawing
'Else If doc.DocumentType = kPartDocumentObject Then
Else
	Goto Other
End If
Return
Drawing:
	modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
CurrentPN = iProperties.Value(modelname, "Project", "Part Number") Try MyDetailViewName = iProperties.Value(modelName, "Custom", "Detail_Part_Number") Catch ' Assume error means not found iProperties.Value(modelName, "Custom", "Detail_Part_Number")= CurrentPN MyDetailViewName = iProperties.Value(modelName, "Custom", "Detail_Part_Number") End Try MyDetailViewName = InputBox("Enter New Detail View Part Number.", "Part Number Needs to be Entered!", MyDetailViewName) iProperties.Value(modelName, "Custom", "Detail_Part_Number") = MyDetailViewName Goto Ending Other: CurrentPN = iProperties.Value("Project", "Part Number") Try MyDetailViewName = iProperties.Value("Custom", "Detail_Part_Number") Catch ' Assume error means not found iProperties.Value("Custom", "Detail_Part_Number")= CurrentPN MyDetailViewName = iProperties.Value("Custom", "Detail_Part_Number") End Try MyDetailViewName = InputBox("Enter New Detail View Part Number.", "Part Number Needs to be Entered!", MyDetailViewName) iProperties.Value("Custom", "Detail_Part_Number") = MyDetailViewName Goto Ending Return Ending: Return ' 'update the file iLogicVb.UpdateWhenDone = True
3 REPLIES 3
jdkriek
in reply to: Ktomberlin
As long as you are doing a check on the document type you can use ThisDoc rather than ThisDrawing
modelName = IO.Path.GetFileName(ThisDoc.ModelDocument.FullFileName)
Example:
'12292 Drawing Document
If doc.DocumentType = 12292 Then
MsgBox(modelName)
End If
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Ktomberlin
in reply to: jdkriek
Thank you, I made that change and it does work now for both drawings and parts. I don't quite understand why when it is run on a part file it even looks at the lines inside of the drawing section.
jdkriek
Glad that worked for you.
Jonathan D. Kriek
