Joshua,
Actually, what I would like to do is have a routine that checked to see if an item
is ballooned or not. If it isn't I would like to turn off the visibility of the item in
the parts list. I currently cannot just compare item numbers because after I
execute my renumber balloons interactive command I am working on, some of the
item numbers may be duplicated. I would have to somehow find filename or
part number references to all the ballooned items and then somehow compare
those each in turn to the item's part number in the parts list. Manualy, I just
select all the parts that don't have balloons and RMB-Visible(off).
Bob S.
"Joshua Verdin" wrote in message news:40fbc558_3@newsprd01...
> Bob,
> From what I can tell yes you could loop through the objects and tell if they
> have been ballooned. I think you woul have to go about it through the
> following method. I beleive you would need to compare the number of parts
> verus the number of balloons. That said there IS NO BALLOON.ADD method I
> don't know why but it doesn't have one. However it does have a Balloon.Add
> method.
> As long as where talking about adding functionallity please include
> Balloon.Add and an AutoBalloon object would greatly easy our live also. If
> possible :-)
> "Bob S." wrote in message
> news:40fbc1eb_3@newsprd01...
> > Can anyone tell me if the expanded Parts Lists API options in IV9
> > includes the ability to tell if an item has been ballooned similar to
> > the way you get a symbol in the Edit Parts List Dialog? From what
> > I have seen (early "trial"), it does not. If this is the case, could
> > someone at AutoDesk suggest methods whereby it could be
> > determined using roundabout obscure code fragments and
> > algorithms? Actually, adding the API capability to SP1 would
> > be greatly appreciated instead of having to resort to compute
> > intensive code to recalculate what should be already known regarding
> > the items in the parts list.
> > Bob S.
> > P.S. Sorry if this sounds like a rant.
