Inventor Customization
Valued Contributor
393 Kudos
Post 1 of 5
isolate an occurrence
300 Views, 4 Replies
08-13-2012 07:17 AM
Hi
i don´t find a way to isolate and undo isolate an occurrence in Assembly can anybody help me wih the right code in VB.
regards Michael
two issues here:
1) the occurrence name contains ‘ : ‘, which is not accepted as a char in file name. This is Windows rule. So e.g.
myPart:1.stp is truncated as myPart.
That is why you saw the file name without extension name. And the file size is 0
2) ControlDefiniton.Execute is Post Command (asynchronously). That means it will be executed after the function which invokes it. So to Send Command (Synchronous), you need to use Execute2(true)
Please refer to the code below. note: you will need to write a method youeself to filter the invalid chars before saving.
    Private Sub test( )
          Dim inventorAppType As Type = System.Type.GetTypeFromProgID("Inventor.Application")
        Dim _invApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        If _invApp.Documents.Count = 0 Then
            MsgBox("Need to open an Assembly document")
            Return
        End If
        If _invApp.ActiveDocument.DocumentType <> _
            DocumentTypeEnum.kAssemblyDocumentObject Then
            MsgBox("Need to have an Assembly document active")
            Return
        End If
        Dim asmDoc As AssemblyDocument
        asmDoc = _invApp.ActiveDocument
        If asmDoc.SelectSet.Count = 0 Then
            MsgBox("Need to select a Part or Sub Assembly")
            Return
        End If
        Dim selSet As SelectSet
        selSet = asmDoc.SelectSet
        Dim compOcc As ComponentOccurrence
        For Each obj In selSet
            If TypeOf obj is ComponentOccurrence then
            compOcc = obj
            If TypeOf compOcc.Definition.Document Is PartDocument Then
                Dim oCtrlDef As ControlDefinition
                'isolate
                oCtrlDef = _invApp.CommandManager.ControlDefinitions.Item("AssemblyIsolateCmd")
                oCtrlDef.Execute2(true)
                Dim oDoc As Document
                ' it is still assembly context. So active document is still the assembly
                'oDoc = _invApp.ActiveDocument
                ' get the corresponding part document.
                oDoc = compOcc.Definition.Document
                Dim oFilename As String
                ' because ': ' is not accepted,
                ' you need to write a function to filter the char
                ' for simple test, i use the part file name
                'oFilename = compOcc.Name & ".stp"
                oFilename = oDoc.DisplayName &  ".stp"
                Dim oFilepath As String
                oFilepath = "c:\temp\"
                Dim oPathName As String
                oPathName = oFilepath & oFilename
                'export step
                Call oDoc.SaveAs(oPathName, True)
                'undo isolate
                oCtrlDef = _invApp.CommandManager.ControlDefinitions.Item("AssemblyIsolateUndoCmd")
            End If
          End If
        Next
    End Sub
ADN Support Specialist
81 Kudos
Post 2 of 5
Re: isolate an occurrence
08-16-2012 11:36 PM in reply to: michael.marx
hi,
I did not fine a direct property to toggle [isolate] or [undo isolate]. But you could select the occurrence and execute the commands .e.g
Sub isolate_undoisolate()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
Set oOcc = oDoc.ComponentDefinition.Occurrences.Item(1)
oDoc.SelectSet.Clear
oDoc.SelectSet.Select oOcc
'isolate
Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyIsolateCmd")
'undo isolate
'Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyIsolateUndoCmd")
oCtrlDef.Execute
End Sub
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Contributor
393 Kudos
Post 3 of 5
08-21-2012 02:07 AM in reply to: michael.marx
hi
Thank you for your reply, but no i have another issue.
Problem description i want to iterate through a select set of occurrences and each occurrence should isolated saved as stp from within the the top assembly with occurrence name.
first problem is the occurence name. with compocc.name & ".stp"  i think i get the name with stp file extension but something went wrong i get a file with the right name but no extension?!?
second problem is the iteration through the select set but i don´t know why.
Sorry for my miserable programming but i´m a newbie to this :-)
Return
End If
Return
End If
Return
End If
compOcc = obj
'isolate
oCtrlDef.Execute()
oFilepath = "d:\temp\"
'export step
'undo isolate
oCtrlDef.Execute()
End If
Next
81 Kudos
Post 4 of 5
08-23-2012 08:45 PM in reply to: michael.marx
two issues here:
    Private Sub test( )
            Return
        End If
            Return
        End If
            Return
        End If
            compOcc = obj
                'isolate
                'export step
                'undo isolate
            End If
          End If
        Next
    End Sub
Xiaodong Liang
Valued Contributor
393 Kudos
Post 5 of 5
08-23-2012 11:02 PM in reply to: michael.marx
thats exactly i want to do!
Thank you for your help.
Michael
