Inventor Customization
Valued Mentor
JohanLarsson
Message 1 of 4 (346 Views)
Is there a way to target .net 4 for an Inventor 2012 add-in?
346 Views, 3 Replies
09-19-2012 12:43 PM
We have a large code base that is migrated to .net 4. I did not find an easy way to target .net 4 when writing an add-in for Inventor 2012.
Is there a solution to this?
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
It seems like I was able to do this once using a "registry-based" addin.  I know it's a step back since we're told to use "registry-free" addins in Inventor 2012 foward, but I think this works.  Can you try that and let us know?
Hi Johan,
Yes, what Farren said seems to work. I assume because of the Side by Side execution feature of .NET 4: http://blogs.microsoft.co.il/blogs/arik/archive/2011/05/30/how-to-use-a-net-4-based-dll-from-net-2-based-application.aspx
Actually, I thought that the Reg-Free version could work as well, but I did not manage to achieve that.
Another thing you can do is force Inventor to use the .NET 4 Framework. This seems to work fine, but still it is unsupported, so if you run into any problems with it then we cannot help.
In order to do that you need to make sure that the <startup></startup> section of Inventor.exe.config has the following:
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntimeversion="v4.0"/>
  </startup
I hope this helps.
Cheers,
FarrenYoung
Message 2 of 4 (328 Views)
Re: Is there a way to target .net 4 for an Inventor 2012 add-in?
09-20-2012 09:05 AM in reply to: JohanLarsson
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Valued Mentor
JohanLarsson
Message 3 of 4 (319 Views)
09-20-2012 11:35 PM in reply to: FarrenYoung
Thank you for this idea, maybe someone from Adesk can chime in and confirm if this is a possibility in theory?
My gut feeling tells me that the problem with the Adesk 3.5 file needing to reference my 4.0 dlls might remain.
Windows 7 64 bit
ADN Support Specialist
adam.nagy
Message 4 of 4 (273 Views)
10-09-2012 11:06 AM in reply to: JohanLarsson
Hi Johan,
Yes, what Farren said seems to work. I assume because of the Side by Side execution feature of .NET 4: http://blogs.microsoft.co.il/blogs/arik/archive/2011/05/30/how-to-use-a-net-4-based-dll-from-net-2-b...
  </startup
I hope this helps.
Cheers,
Adam Nagy
Developer Technical Services
Autodesk Developer Network
