Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
I'm assuming you are talking about a template for creating Add-ins?
If so, you can download a template from the link below that sets everything up for you, Just install it and choose it in Visual Studio.
http://www.spiderinnet2.typepad.com/blog/2012/06/a-wizard-for-inventor-net-addin.html%20
Hi
yeah i had found this before. I have uninstalled it and reinstalled it but i cannot see what it has done. i still only have the Autodesk SDK template available in my project templates folder and nothing inside VS that shows as a tool..
How exactly does it work? 🙂
Nigel
Nacho
Hi
i am using 2013 but i think the tool only supports upto 2010?
Cheers 🙂 & happy New Year
Nige
Nacho
That is true, but I was able to copy some files and make it work in 2013. Below is a link to a video I made showing what files to move and where.
https://drive.google.com/file/d/0B4HAiI1y8s_ZSFgyOUtoSkZvT0U/view?usp=sharing
Hi
i appreciate the video. I cant find the files on my drive at all. i have uninstalled and reinstalled about 4 times. Are you able to zip the files and dropbox them at all? i can manually place them in my templates folder.
i recently made a tool to help me make code snippets if you are interested?
also
after making the snippet tool, it occured to me that the .addin files are also xml based so i am going to copy it and modify some code to allow a simple fill in box to create a .addin file for the application (just in case). i can put the tool in the same dropbox folder.
Here is a video link 🙂 http://screencast.com/t/eJR5cVHla
Cheers
Nacho
I have attached the files. Make sure you have the template program from that site as well. It has some .dll files that Im sure it will need.
That snippets tool looks very useful. Thanks!
Hi
I copied everything you did but i cannot get the template to appearwhen i select to make a new project... I followed your video and also placed the files where my templates (and the AD inventor templates) are located (My Documents\Visual Studio 2013\Templates\
confused lol :s
Cheers
Nacho
Nacho
