Hi to all,
I'm trying to Copy an Assembly via the Apprentice Server functionality.
But I don't want to copy all files with the filesave as feature. Some of the files, has to be used again as the source file. For Example Content Center files should not be copied. Or maybe also some specific defined internal standard files.
Is there a possibility to get this work?
In the moment, I got all these files via:
[...] For each Element As Inventor.ApprenticeServerDocument In doc.AllReferencedDocuments [...]
maybe it's possible to say something like that:
If Element=ContentCenterDocument then BlaBlaBla
Maybe, there's a simple solution. I know, there's an "Inventor.ObjectTypeEnum.kContentCenterObject", but I don't know, how to use it, to check the ApprenticeServerDocument with that.
Best Regards
Passi
Looks interesting, I will check that 🙂
But I think, you're right.
Best Regards
Passi
