Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor VB.Net "Addin" modification help?
1 REPLY 1
isocam
313 Views, 1 Reply
Can anybody help?
I vave the following code used in a VB.Net "Addin".
Private Sub m_applicationEvents_OnSaveDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_applicationEvents.OnSaveDocument
REM EXIT THE SUB HERE IF THE "NO" BUTTON IS PRESSED!!!!
If BeforeOrAfter = EventTimingEnum.kAfter Then
Try
Dim invVBAProject As InventorVBAProject = m_inventorApplication.VBAProjects.Item(1)
Dim invModule As InventorVBAComponent = invVBAProject.InventorVBAComponents.Item("Module03")
Dim invSub As InventorVBAMember = invModule.InventorVBAMembers.Item("OnSave")
invSub.Execute()
Catch ex As Exception
End Try
End Sub
I need to modify the above code so that if the "No" button is pressed (Please see the attached file) I exit the Sub Routine.
Does anybody know how to do this?
Many thanks in advance!!!!
Darren
1 REPLY 1
rossano_praderi
in reply to: isocam
Hi Darren,
If DocumentObject.Dirty Then ....
The document become dirty (True) on every modification, after save this property is False.
I suggest to verify this property after the follow line of your code:
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
