I have several parts that are controlled by ilogic rules linked to member names ,and in some cases some of staff run the productivity bonus tool (rename browser nodes) to either file name or part number.
This causes the rules to fail as rules definition name have been overwritten.
I am after a simple rule that is triggered on save to save my occurrence browser name to what originally was defined
Dim Browsername As String = Plywood 01
Any help on this would be appreciated
Member names example
Plywood 01
Plywood 02
Plywood 03
Plywood 04
Regards
Dave
Hi dclunie,
I think this iLogic snippet does what you're after.
I hope this helps.
Curtis
oName = InputBox("Enter a Name", "iLogic", "Plywood") ' set a reference to the assembly component definintion. ' This assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition i=0 'Iterate through all of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences i=i+1 oOccurrence.Name = oName & ":" & i Next
Hi dclunie,
Just in case you're wanting to simply reset the name for each component rather than set a name for each one, here is another snippet to do so.
I hope this helps.
Curtis
' set a reference to the assembly component definintion. ' This assumes an assembly document is open. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'Iterate through all of the occurrences Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences oOccurrence.Name = "" 'reset name to nothing, which pulls in the original name Next
Hi Curtis
Thanks that is great however is there a way to have it so it is a rule in itself attached to individual .ipt files so taht when we hit save it automatically names occurrence as in rule.
We have a few files in each assembly and we know what they need to be called but when we have input box we are unable to define if we are giving it the same name as originally defined.
oName= Plywood 01
regards
Dclunie
Hi
I am after some more help if you dont mind, in our office we have started developing ilogic controlled assemblies.we give the occurrence name like lh side and rh side etc,and all code references that occurrence name to control assembly.
However thanks to productivity tool in inventor some people hit rename browser nodes command in which basically a ticking time bomb for ilogic code and the code will fail .
What i am thinking is that if we give the title in the summary tab in inventor iproperties the name we desire for the occurrence name we can run a rule on save to change part occurrence back to desired name giving the code a chance to stay viable.
Any help would be appreciated
Dave
hi,
This is a small code for your reference. copy it to iLogic rule of the assembly. It checks the Title of the part and changes the occurrence name. But it does not consider the scenario if there is multi occurrences from same part. e.g.
mypart:1
mypart:2
because they are from the same part.The Title property is same. You will need to write a function to check if the name has been used and provide the names such as:
titlevalue:1
titlevalue:2
oAssDoc = ThisDoc.Document oAssDef = oAssDoc.ComponentDefinition Dim oOcc As ComponentOccurrence For Each oOcc In oAssDef.Occurrences ' if this is a part If TypeOf oOcc.Definition.Document Is PartDocument Then oPartDoc = oOcc.Definition.Document 'Summary Information oPSet = oPartDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}") ' Title oP = oPSet.ItemByPropId(2) ' if the property value is not empty, change the occurrence name If oP.Value <> "" Then oOcc.Name = oP.Value End If End If Next
HI all, i'm very happy to find this thread..
my questions..
I have a nozzle. and in assembly I need to add this nozze more than two valve.
I can use methode in this thread to customize item name using part occurence name.
and my problem is, how to put this occurence name to Part List?
ie..
Mark size Service Connections
N1 Ø30 Spraying Device DINxxx
N2 Ø30 Spraying Device DINxxx
N3 Ø30 Spraying Device DINxxx
note : N1,N2,N3 is one part and one file.
thanks before...
Hi there,
I just want to rename one specific occurrence in the model browser through iLogic, not every compnent. Is there a way to do this?
i have a variant of this problem. i use a for for each document on an assembly , like this:
For Each doc In asmDoc.AllReferencedDocuments
so i can see the filename of each part
and i want to see the occurence name of "doc" not of every part in the assembly, is possible?
