Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor ipart setting template
3 REPLIES 3
332 Views, 3 Replies
Good day to all,
I have question about ipart options, the question is May I setup the template of ipart version start at the first row with number "...-00"
Because now when we clicking to create ipart the first row of version start 'part-01' on the column member and Part Number.
For more clear you can see the picture in an attachment.
My Inventor version: 2013 SP2 update 6
Thank you in advance for all suggestion.
Best Regards,
3 REPLIES 3
salariua
I've manage to do it. First I've renamed the member and part number then clicked on options and changed start value.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
in reply to: salariua
Hi Salariua,
with you solution, I have to set the options everytime when create new ipart. but my taget is no need to set everytime, I need same right template setup.
Do you have another solution?
Thank you for you share.
Best regards,
Bird.
salariua
I am afraid I dont' have another solution , I edit the table via excel normally.
Adrian S.
blog.ads-sol.com
