Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor ilogic create assebmyl constraints
2 REPLIES 2
craigzcool
1812 Views, 2 Replies
        Im after programatically mating 2 components together in an assembly. My stages are as follows:
1)Create New Assembly
2)Add .ipt's
3) One-by-one, mate all the parts together (each part has a plane named "WPStart" and "WPEnd". In each part im after the WPStart being flush mated with the WPEnd of the 2nd part - see image attached. In addition I would like to mate al the XZ planes in each of the parts fluch together and likewize the YZ planes.
3) Mate the parts together
Dim FlushConst As FlushConstraint
FlushConst.AffectedOccurrenceOne = oAssyDoc.ComponentDefinition.Occurrence.Item(1).Workplanes.ItemByName("WPStart") <--------
FlushConst.AffectedOccurrenceTwo = oAssyDoc.ComponentDefinition.Occurrence.Item(2).Workplanes.ItemByName("WPEnd")  <--------
The two lines above I have made up but i was hoping/expecting the solution would follow a similar logic.
Any advice ewould be appreciated
Thanks, Craig
2 REPLIES 2
craigzcool
in reply to: craigzcool
 found this post which uses surface bodies. The solution to Blokkie862 question was never solved.
http://forums.autodesk.com/t5/Inventor-General/iLogic-Insert-Constraint/td-p/3938946
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim colCons As AssemblyConstraints
colCons = oDoc.ComponentDefinition.Constraints
Dim oOcc1 As ComponentOccurrence
Dim oOcc2 As ComponentOccurrence
oOcc1 = oDoc.ComponentDefinition.Occurrences(1)
oOcc2 = oDoc.ComponentDefinition.Occurrences(2)
Dim oEntity1 As Object
Dim oEntity2 As Object
oEntity1 = oOcc1.SurfaceBodies(1).Faces(1) <-------------------------------
oEntity2 = oOcc2.SurfaceBodies(1).Faces(2) <-------------------------------
colCons.AddFlushConstraint(oEntity1, oEntity2, 0)
I need to swap the 2 lines above to select workplanes instead of surface bodies. does anyone have any idea how i would go about this?
craigzcool
I found this post which solves my problem. I ihave tweeked the code to suit my application:
http://adndevblog.typepad.com/manufacturing/2013/06/constraint-an-assembly-workplane-with-a-componen...
My code:
   ' get the active component definition
        Dim oAsmCompDef As AssemblyComponentDefinition
        oAsmCompDef = oAssyDoc.ComponentDefinition
        ' create geometry proxy 1
        oOcc1 = oAsmCompDef.Occurrences(1)
        Dim oPartPlaneXZ As WorkPlane
        oPartPlaneXZ = oOcc1.Definition.WorkPlanes(2)
        Dim oPartPlane1 As WorkPlaneProxy = Nothing
        oOcc1.CreateGeometryProxy(oPartPlaneXZ, oPartPlane1)
        ' create geometry proxy 2
        oOcc2 = oAsmCompDef.Occurrences(2)
        Dim oPart2PlaneXZ As WorkPlane
        oPart2PlaneXZ = oOcc2.Definition.WorkPlanes(2)
        Dim oPart2Plane1 As WorkPlaneProxy = Nothing
        oOcc2.CreateGeometryProxy(oPart2PlaneXZ, oPart2Plane1)
        ' and finally add the constraint
        oAsmCompDef.Constraints.AddMateConstraint(oPartPlane1, oPart2Plane1, 0)
