Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor Drawing View Dialog Box
1 REPLY 1
rcasper
384 Views, 1 Reply
Hello All,
Looking for a little iLogic help.  Currently have an iLogic rule in my drawing template that base on user input brings up the Drawing View dialog box (as though you click on base view).  I want to know if there is some coding I can do to control or handle what happens if the user clicks the cancel command inside this dialog box.  Possibly show a message box. Or even run another rule after the cancel button has been clicked?
1 REPLY 1
adam.nagy
in reply to: rcasper
You could run the "Base" command synchronously and check if the number of views on the sheet changed once the command finished. If it's the same then you can assume that the command got cancelled.
oCM = ThisApplication.CommandManager
oDefinition = oCM.ControlDefinitions("DrawingBaseViewCmd")
oSheet = ThisApplication.ActiveDocument.ActiveSheet
count = oSheet.DrawingViews.Count
MsgBox("before - " + Str(count))
oDefinition.Execute2(True) ' synchronous = True
If count = oSheet.DrawingViews.Count Then
	MsgBox("after - " + Str(oSheet.DrawingViews.Count) + _
	" - Base command got cancelled")
Else
	" - Base command succeeded")
End If
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
