Hi there, we are currently reviewing our company CAD procedures to bring it more in line with British Standard 8888 (the old BS 308) - one thing we have noticed in the standard is that they now require each group of three digits either side of the decimal marker to have one space between each group, e.g a dimension value of "4000" should display as "4 000", "3.0625" should display as "3.062 5" etc - we cant see anything in the settings which would allow us to do this, does anyone know if we can please? Using Inventor 2014. Thanks.
Solved by Jon.Dean. Go to Solution.
Currently there is nothing in place to space the text as you describe.
The best way forward is for you to register this enhancement on the IdeaStation.
Developers and QA monitor this forum and I'm sure would like to adhere to drawing standards.
Whatever BSI do, ISO and DIN are sure to follow, if not already.
Here is the link:
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
Jon.
