Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor 32bits and 64bits API
3 REPLIES 3
543 Views, 3 Replies
It will possible run the same application addin in both Inventors 32bits and 64bits?
For example, if the addin is developend in 32bits it will work in Inventor 64bits plataform?
Or it will be necessary create and compile 2 different addins?
For example in Office 2013 it will be possible compile the addin for both platforms and use the same addin in both offices (32bits and 64bits).
Thanks & Regards,
Rui
3 REPLIES 3
philippe.leefsma
If you use a .Net add-in then it's possible, because your add-in is compiled with "Any CPU" (by default), so it is compiled into machine code at runtime.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
in reply to: philippe.leefsma
I am using a .Net add-in compiled with "Any CPU".
I have the Inventor 32bits installed. When I add references like "adwindows", "Autodesk.Inventor.Interop.dll" from my Inventor 32bits, the addin still supporting any cpu?
These dlls support any cpu?
Thanks & Regards,
Rui
philippe.leefsma
That should not be a problem: for "Autodesk.Inventor.Interop.dll" definitely. For the adwindows.dll, set it to Copy Local = False. It will be loaded anyway by whatever version of Inventor your addin gets loaded into.
Philippe.
Philippe Leefsma
