Hello Everyone!
This is my first time posting on the AutoDesk forums.
Background of Problem:
The company I work for builds automation for another company and we have both transitioned to Inventor 2015 this past week. We have created automation modules for the company we are working for to speed up their development process, one of the things the modules do is link up with excel documents. At one point you fill out an excel document with a few different values that are later tied into the model. This opens up a template that we have on a vault. In Inventor 2014 it opened up outside of Inventor in a seperate window, after we began transitioning to Inventor 2015 it started showing up inside of the design window. It is zoomed out too far to even be useful and you can not zoom in.
Was there something new added with Inventor 2015 that changes the way that excel documents open?
If so how do i fix it?
I will post pictures if it would make it easier to understand my issue.
Thanks for taking your time to read about my issue, if anyone can answer my questions that would be awesome! In the meantime I am going to do further reasearch to figure out how to fix this. Time is precious!
Again, Thanks!
Can anyone give some in sight on why my excel document is being created inside of Inventor? I just need to know if I can turn it off or not, and if I can't how do i edit the settings so its not zoomed so far out.
The code that causes the excel document to open is
'Opens the embedded excel file when it is ran Imports Inventor.OLEDocumentTypeEnum ExcelApp = CreateObject("Excel.Application") Dim ExcelFile As ReferencedOLEFileDescriptor ExcelFile = ThisDoc.Document.ReferencedOLEFileDescriptors.Item(1) ExcelFile.Activate(kEditOLEVerb, ExcelApp)
The line of code causing the problem:
However it worked fine before in Inventor 2014. After reasearching i found that kEditOLEVerb is supposed to open the document in another window to be edited.
If anyone has any information on why this would have changed, PLEASE let me know. Thank you.
Hello AfterWar24,
Do you already have a solution for your issue?
I noticed that if you place a breakpoint on the XL.Close command (the program stops at this step) and you step over it with F8 key, than the excel process will actually stop.
Without the breakpoint, the excel process does not stop.
Many thanks in advance,
Anco
