I have been chancing the default measurement options like in this photograph.
1. Tools - Application Options - File - Configure Default Template...
2. Metrics and DIN norms.
3. Click OK, Click Overwrite
it turns to metrics but after closing program and re-opening, it returns to inches again.
I dont have any deepfreezing program on my PC. I just formatted my hard drive, and installed Win 8.1. x64. after driver installation. I installed Inventor 2015. It is not pro versionş it is design suit.
Solved by salariua. Go to Solution.
Make sure you use same project file. From my experience the settings from the last inventor session you close down will be preserved so do the changes with only one inventor session open and restart it to check the changes.
If not, do it manually by going in tools options files and open the template file folder. Copy the ones in DIN over the standard ones (make sure you rename them to standard.ipt, .iam idw. ipt )
Get back to us if it's still not playing.
