Where can I find the 2015 API object model? The link on this page (http://usa.autodesk.com/adsk/servlet/index?id=1079044&siteID=123112) still points to the 2014 object model.
Regards, Daniƫl
Solved by YuhanZhang. Go to Solution.
You can install the C:\Users\Public\Documents\Autodesk\Inventor 2015\SDK\DeveloperTools.msi and then find thethe \DeveloperTools\Docs\Inventor2015ObjectModel.pdf.
Hope this helps.
