Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
inventor 2014 VBA cant see DLLs
1 REPLY 1
276 Views, 1 Reply
Hello. I Know that inv 2014 has is 64 bit and has new version of VB, but I can still use for example windows 32bit DLL  (Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As LongPtr) ), but when I try to import other 32bit created in VC++, the VBA simply refuses to work. CAn anyone help? Why one 32 bit dll work and other not? I got message "File not found" where the file is 100% in good place.
1 REPLY 1
philippe.leefsma
Hi
On 64-bit platform, the Kernel is definitely a 64-bit dll. It's always called kernel32.dll, even on 64-bit windows. This is for the same compatibility reasons that system32 contains 64-bit binaries, while syswow64 contains 32-bit binaries.
You will have to compile your dlls for 64-bit if you want to be able to import functions under VBA x64.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
