Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor 2014 SDK Installation issue with Windows 8
12 REPLIES 12
Message 1 of 13
1483 Views, 12 Replies
SDK installation fails in windows 8 x64.
12 REPLIES 12
Message 2 of 13
YuhanZhang
Can you share a bit more info to us:
1. If you log on win8 with admin priviledge?
2. Have you the UAC on or off?
3. Which Win8 version you are using?
I tested the installer here and could not see the error dialog.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 13
peteh
in reply to: YuhanZhang
Inventor API is not compatable with Windows 8.
I reported an issue durring the beta testing.  The problem was confirmed and I was told it was logged as defect 1493613.
Message 4 of 13
YuhanZhang
in reply to: peteh
Ah yeah, it is about the <requestedExecutionLevel level="asInvoker" uiAccess="false" /> and UAC on. Current workaround might be disabling the UAC.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 5 of 13
1. Loged with admin privilege
2. UAC OFF
3. Windows 8 Pro. 64bit
Message 6 of 13
I was able to install the SDK after changing the installer into compatibility mode
Message 7 of 13
YuhanZhang
Glad to hear that it works now.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 8 of 13
noontz
in reply to: peteh
"Inventor API is not compatable with Windows 8"
Please could someone from Autodesk comment on this one?
Is this still an issue? Is there a hotfix / guidelines I´m not aware of (other than Rockys reply)?
Message 9 of 13
in reply to: noontz
It is compatable with windows 8 . By changing full rights to windows temp folder the installer can be used, Install VBA 7 (64 bit) seperatly from the installation disk. then every thing will be fine.
Message 10 of 13
noontz
Thx for the reply! I´m not concerned about the SDK install, so I´m slightly out of topic here. Sorry. It´s the API as Peteh mentions I´m wondering about, since we have run into some crashes on win8 with an addin running running fine on w7, but hopefully it´s something else than API compatibility ( I ran into this topic searching for win8 issues ).. I´m on C#, VS2012, & 64b.
Message 11 of 13
philippe.leefsma
in reply to: noontz
The Inventor API is compatible with Windows 8 and it is a supported platform. I have several custom add-ins that run fine on Win8 x64 and there is no specific issue we are aware of. If you experience troubles on windows 8, please let us know in details.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 12 of 13
peteh
in reply to: philippe.leefsma
Durring the beta I discovered that if having a .net program running as administrator I could not start Inventor 2014.
I reported the problem and provided a sample in the beta forum and the problem was confirmed by "yuhanzhang" and logged as defect #1493613
I do not know how to check the defect status.
Message 13 of 13
philippe.leefsma
in reply to: peteh
Hi Peteh,
This change request has been confirmed but is still pending unfortunately.
Philippe.
Philippe Leefsma
