I've looked around to try and find a useful resource for Inventor ribbon names and such with pretty much no luck so I generated my own for Inventor 2014. I decided to post this here incase someone else might find it useful during macro or add-in development.
Sample......
#### Inventor 2014 Ribbons, Tabs & Panels Map ####
Ribbon Name: ZeroDoc
ZeroDoc Tabs & Panels...
Tab Name: Get Started.................................Internal Name: id_GetStarted
Panel Name: Launch························Internal Name: id_Panel_Launch
Panel Name: New Features················Internal Name: id_Panel_GetStartedWhatsNew
Panel Name: Videos and Tutorials········Internal Name: id_Panel_Tutorial
Tab Name: Tools...........................................Internal Name: id_TabTools
Panel Name: Options·······················Internal Name: id_PanelP_ToolsOptions
Panel Name: Content Center···············Internal Name: id_PanelZ_ToolsContentCenter
Panel Name: iLogic·························Internal Name: iLogic.RibbonPanel
Panel Name: Web···························Internal Name: id_PanelP_ToolsWebTools
Tab Name: Add-Ins......................................Internal Name: id_AddInsTab
Tab Name: Inventor Debug..........................Internal Name: id_InventorDebugTab
Tab Name: Exit Tutorial..............................Internal Name: id_TabTutorial_Exit
Panel Name: Exit Tutorial·················Internal Name: id_Panel_TutorialExit
Tab Name: Autodesk 360.............................Internal Name: id_OnlineTab
Panel Name: Access························Internal Name: id_Panel_OnlineDocument
Panel Name: Simulation····················Internal Name: id_Panel_Simulation
Thank you very much, This will come in very handy. Always good to get some help with customizing 😃
Here is a similar list for Inventor 2023 ribbons. I am not 100% sure if it is comprehensive or not, but there's a lot there.
The code to generate this list is shown below (C#). Note that there is no "display name" for ribbons, as they are not shown by name to the user.
var userInterfaceManager = _thisApplication.UserInterfaceManager;
using var sw = new StreamWriter("c:\\temp\\InventorRibbons.csv");
sw.WriteLine($"Ribbon,Tab Name,Tab Internal Name");
foreach (Ribbon oRibbon in userInterfaceManager.Ribbons)
foreach (RibbonTab oTab in oRibbon.RibbonTabs)
sw.WriteLine($"{oRibbon.InternalName},{oTab.DisplayName},{oTab.InternalName}");
sw.Close();
Thanks for the contribution, lol and love the screen name.
This variation also shows the panels and writes them to the logger:
For Each ribbon As Ribbon In ThisApplication.UserInterfaceManager.Ribbons
Logger.Info(vbTab & Ribbon.InternalName)
For Each ribbonTab As RibbonTab In Ribbon.RibbonTabs
Logger.Info(vbTab & vbTab & RibbonTab.DisplayName & " - " & RibbonTab.InternalName)
For Each ribbonPanel As RibbonPanel In RibbonTab.RibbonPanels
Logger.Info(vbTab & vbTab & vbTab & RibbonPanel.DisplayName & " - " & RibbonPanel.InternalName)
Next
Next
Next
Dim loggerWindow = ThisApplication.UserInterfaceManager.
DockableWindows.
Cast(Of DockableWindow).
Where(Function(d) d.InternalName.Equals("ilogic.logwindow")).
First()
loggerWindow.Visible = True
It's taken from my blog post/tutorial "Creating an Inventor Addin".
Jelte de Jong
Blog: hjalte.nl - github.com
I got very tired of remembering where I saved this, and not having enough items documented. I created a running database that shows all of this information. It includes code samples as well.
