Is there an Inventor Api property/method that I can use to turn off the Immediate Update option on the Parameters dialog?
We are using Inventor 2014 api with Excel AddIns to modify legacy parts that were created before the option for Immediate Update existed. Apparently when opening those parts this option is turned on and causing issues for our processes. Our preference is not to require the users to manually turn that option off. We would prefer having the Addin programmatically turn it off.
It seems that there is no API to change that option in the Parameters dialog, but I think that is only relevant to that dialog: i.e. when the user changes a parameter in that dialog.
As I understand you are changing things through the API, so the model should not update straight away after each parameter value gets changed.
Maybe you could describe in more detail what the exact problem is?
Cheers,
We just migrated from 2010 to 2014. Jumping 4 versions had caused a couple of issues with an Addin we were using. Thought part of our issue might have been related to "parameter immediate" option possibly causing the model to update as each parameter was getting modified programatically.
As it turns out .. .slight changes in the Reference Documents objects was the culprit.
