For our automtisation macro, I've been trying to include assembly View reps and/or Pos Reps in the DWF publish process.
After a lot of searching, I created two functions that can be used as a addition to the "Export to DWF" example macro in the "Inventor API help".
I like to shere them with you because I could not find a simple ready to use example.
'Adds all current Design View Representations from the specified assembly document to the specified DWF publish options Private Sub AddAllDesignViewRepresentationOptions(ByVal oAssyDoc As AssemblyDocument, ByVal oOptions As NameValueMap) 'Set reference to the design view representations Dim oDesViewReps As DesignViewRepresentations Set oDesViewReps = oAssyDoc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations If oDesViewReps.Count > 0 Then 'Add all design view representations to the publish options Dim oDesViewRep As DesignViewRepresentation Dim oDesViewRepNVM As NameValueMap Dim oDesViewRepOptions As NameValueMap Set oDesViewRepOptions = ThisApplication.TransientObjects.CreateNameValueMap Dim i As Integer i = 0 'loop trough all design view reps For Each oDesViewRep In oDesViewReps i = i + 1 Set oDesViewRepNVM = ThisApplication.TransientObjects.CreateNameValueMap oDesViewRepNVM.Add "Name", oDesViewRep.Name oDesViewRepOptions.Value("Design_View" & i) = oDesViewRepNVM Next oOptions.Value("Design_Views") = oDesViewRepOptions End If End Sub 'Adds all current Positional Representations from the specified assembly document to the specified DWF publish options Private Sub AddAllPositionalRepresentationOptions(ByVal oAssyDoc As AssemblyDocument, ByVal oOptions As NameValueMap) 'Set reference to the positional representations Dim oPosReps As PositionalRepresentations Set oPosReps = oAssyDoc.ComponentDefinition.RepresentationsManager.PositionalRepresentations If oPosReps.Count > 0 Then 'Add all positional representations to the publish options Dim oPosRep As PositionalRepresentation Dim oPosRepNVM As NameValueMap Dim oPosRepOptions As NameValueMap Set oPosRepOptions = ThisApplication.TransientObjects.CreateNameValueMap Dim i As Integer i = 0 'Loop trough all pos reps For Each oPosRep In oPosReps i = i + 1 Set oPosRepNVM = ThisApplication.TransientObjects.CreateNameValueMap oPosRepNVM.Add "Name", oPosRep.Name oPosRepOptions.Value("Positional_Representation" & i) = oPosRepNVM Next oOptions.Value("Positional_Representations") = oPosRepOptions End If End Sub
If you added the code above, you can add this piece of code to the macro example from the "Inventor API help" or to you own custom DWF publish code.
If TypeOf oDoc Is AssemblyDocument Then 'Set custom DWF publish mode oOptions.Value("Publish_Mode") = kCustomDWFPublish 'Set reference to the assembly document Dim oAssyDoc As AssemblyDocument Set oAssyDoc = oDoc 'Add all design view reps to the publish options AddAllDesignViewRepresentationOptions oAssyDoc, oOptions 'Add all pos reps to the publish options AddAllPositionalRepresentationOptions oAssyDoc, oOptions End If
Hope it helpes!
