Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Interference of solids and line segment
2 REPLIES 2
360 Views, 2 Replies
Hello.
I'm trying to figure a "fast" algorithm to obtain the amount of material (in linear distance) between 2 points within an assembly i.e. if I draw a line between any two points P1 & P2 in an assembly, what is the length of this segment that goes trogh material and what is the length that goes trough empty space?
For now I'm creating a thin cyilinder as a new part, place it with one end at P1 and the other end at P2, calculate the inerference volume of this body with the rest of the assembly and divide this number by the total volume of the cylinder. This method gives me the rigth answer, but has some problmes:
1. It is VERY slow, and I want to call this function lots of times.
3. Is not accurate due to the finite diameter of the cylinder.
2. If the assembly has some interferences, the result is wrong (acounting same volume more than once)
Any idea to improve this calculation will be much appreciated.
Tanks in advance
Pablo
Tags (1)
2 REPLIES 2
adam.nagy
Hi Pablo,
It probably depends on the model, but in my tests the following code I wrote seemed to work fast enough:
Sub CheckIntersection()
    Dim doc As AssemblyDocument
    Set doc = ThisApplication.ActiveDocument
    Dim wp1 As WorkPoint
    Dim wp2 As WorkPoint
    Set wp1 = doc.SelectSet(1)
    Set wp2 = doc.SelectSet(2)
    Dim sp As Point
    Set sp = wp1.Point
    Dim ep As Point
    Set ep = wp2.Point
    Dim dir As Vector
    Set dir = sp.VectorTo(ep)
    Dim dist As Double
    dist = sp.DistanceTo(ep)
    Dim filter(1 To 1) As SelectionFilterEnum
    filter(1) = kPartFaceFilter
    Dim pts As Variant
    Dim oe As ObjectsEnumerator
    Set oe = doc.ComponentDefinition.FindUsingVector( _
        sp, dir.AsUnitVector, filter, , , , pts)
    Dim i As Integer
    For i = 1 To oe.Count
        Dim pt As Point
        Set pt = pts(i)
        ' If we are going beyond the end point then
        ' let's stop
        If sp.DistanceTo(pt) > dist Then
            Exit For
        Dim f As Face
        Set f = oe(i)
        Dim se As SurfaceEvaluator
        Set se = f.Evaluator
        Dim ptData() As Double
        pt.GetPointData ptData
        Dim normals() As Double
        se.GetNormalAtPoint ptData, normals
        Dim n As Vector
        Set n = ThisApplication.TransientGeometry.CreateVector()
        Call n.PutVectorData(normals)
        ' Check if the section up till the intersection point
        ' was inside a solid or outside
        ' If the face's normal is the same direction
        ' as we are going, then we are leaving the solid through
        ' this face
        Dim isInside As Boolean
        isInside = n.DotProduct(dir) > 0#
        Dim length As Double
        Select Case i
            Case 1:
                length = sp.DistanceTo(pt)
            Case oe.Count:
                length = ep.DistanceTo(pt)
            Case Else:
                length = pt.DistanceTo(pts(i - 1))
        End Select
        Debug.Print str(length) + " section inside solid = " + str(isInside)
    Next
End Sub
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Thanks very much Adam.
This is a much more "elegant" solution.
Pablo
