Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Insert Surface And Extrude To it using Ilogic
3 REPLIES 3
491 Views, 3 Replies
Hi Everyone,
I’m a design engineer for a company that make press tooling to manufacture parts. I am trying to automate the design process using Ilogic. I know the basics but the part I’m having trouble with is importing a surface.
Our process is to 3D scan the part which then gets a surface from this and extrude up to the actual surface.
Is there any way in ilogic to automate this process. Ideally I would like it to come up with a browse button you select the surface file .stp or .iges. Once the surface is in the part file it extrudes up to the surface from a plane.
Any Ideas Anyone
Cheers
Chris
Tags (2)
3 REPLIES 3
xiaodong_liang
in reply to: xiaodong_liang
Thanks for the reply, the link you've sent is broken and chance of you posting another. It looks like it could be very useful.
Cheers
Chris
xiaodong_liang
I am not sure why the link changed. Currently it is:
http://forums.autodesk.com/t5/Autodesk-Inventor/Extrusion-using-iLogic/m-p/3573250/highlight/true#M4...
In case you cannot still access, please go to the board (Autodesk Inventor) and search by "Extrude iLogic".
