Inventor Customization
Valued Contributor
chrisrodway
Message 1 of 4 (234 Views)
Insert Surface And Extrude To it using Ilogic
234 Views, 3 Replies
10-11-2012 08:22 AM
Hi Everyone,
I’m a design engineer for a company that make press tooling to manufacture parts. I am trying to automate the design process using Ilogic. I know the basics but the part I’m having trouble with is importing a surface.
Our process is to 3D scan the part which then gets a surface from this and extrude up to the actual surface.
Is there any way in ilogic to automate this process. Ideally I would like it to come up with a browse button you select the surface file .stp or .iges. Once the surface is in the part file it extrudes up to the surface from a plane.
Any Ideas Anyone
Cheers
Chris
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
ADN Support Specialist
xiaodong.liang
Message 2 of 4 (177 Views)
Re: Insert Surface And Extrude To it using Ilogic
10-24-2012 01:45 AM in reply to: chrisrodway
Could you take a look if this post helps?
http://forums.autodesk.com/t5/Autodesk-Inventor/Extrusion-using-iLogic/td-p/3573250
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Contributor
chrisrodway
Message 3 of 4 (153 Views)
11-12-2012 03:23 AM in reply to: xiaodong.liang
Thanks for the reply, the link you've sent is broken and chance of you posting another. It looks like it could be very useful.
Cheers
Chris
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
xiaodong.liang
Message 4 of 4 (138 Views)
11-14-2012 07:29 PM in reply to: chrisrodway
I am not sure why the link changed. Currently it is:
http://forums.autodesk.com/t5/Autodesk-Inventor/Extrusion-using-iLogic/m-p/3573250/highlight/true#M4...
In case you cannot still access, please go to the board (Autodesk Inventor) and search by "Extrude iLogic".
Xiaodong Liang
