Insert a row in iPart
3 REPLIES 3
santoshr0114
756 Views, 3 Replies
I want to insert a row which contains data into iPart as new part member but without using excel.
Is there a way to do so ?
Regards
Santosh
3 REPLIES 3
ekinsb
in reply to: santoshr0114
You can use the API for iparts to add a new row.  The other response I posted regarding your question about deleting a row shows how to access the TableRows object which provides access to all of the rows in the table.  To add a new row you need to use the Copy method of the TableRow object.
Brian Ekins
Mod the Machine blog
santoshr0114
in reply to: ekinsb
ekinsb,
I didn't know this. Will Try and post the code if successful.
Thank You
Regards
Santosh
santoshr0114
in reply to: ekinsb
ekinsb,
I got that method and finished implementing...
Thank You for the guidance
Regards
Santosh
