I want to insert a row which contains data into iPart as new part member but without using excel.
Is there a way to do so ?
Solved by ekinsb. Go to Solution.
You can use the API for iparts to add a new row. The other response I posted regarding your question about deleting a row shows how to access the TableRows object which provides access to all of the rows in the table. To add a new row you need to use the Copy method of the TableRow object.
