Hi Everyone,
I ve got this idea but not sure where to begin or if its possible to do in Inventor.
Does anyone know how or if its possible to insert a DataGrid into a Inventor drawing using VB or C#
i would think this may be possible, if you think out it a "Parts List" is a DataGrid.
if anyone can help with this id appreiciate it.
Jeremy
Can you explain in more detail you envision this working?
Take a look at the 'Programming Help' in Inventor (click the '?' > Community Resources > Programming Help)
There's a good example in there to create a custom table :
Public Sub CreateCustomTable() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Set the column titles Dim oTitles(1 To 3) As String oTitles(1) = "Part Number" oTitles(2) = "Quantity" oTitles(3) = "Material" ' Set the contents of the custom table (contents are set row-wise) Dim oContents(1 To 9) As String oContents(1) = "1" oContents(2) = "1" oContents(3) = "Brass" oContents(4) = "2" oContents(5) = "2" oContents(6) = "Aluminium" oContents(7) = "3" oContents(8) = "1" oContents(9) = "Steel" ' Set the column widths (defaults to the column title width if not specified) Dim oColumnWidths(1 To 3) As Double oColumnWidths(1) = 2.5 oColumnWidths(2) = 2.5 oColumnWidths(3) = 4 ' Create the custom table Dim oCustomTable As CustomTable Set oCustomTable = oSheet.CustomTables.Add("My Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _ 3, 3, oTitles, oContents, oColumnWidths) ' Change the 3rd column to be left justified. oCustomTable.Columns.Item(3).ValueHorizontalJustification = kAlignTextLeft ' Create a table format object Dim oFormat As TableFormat Set oFormat = oSheet.CustomTables.CreateTableFormat ' Set inside line color to red. oFormat.InsideLineColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) ' Set outside line weight. oFormat.OutsideLineWeight = 0.1 ' Modify the table formats oCustomTable.OverrideFormat = oFormat End Sub
