Does anyone know what the code for prompting a user to select which sheets to export as DXF's might entail? I think an input box with a populated radio group would be the best option here. Maybe a for loop adding 1 To ThisDoc.Document.Sheets.Count to a msgbox variable? Ideally it would remember This choice for the next time as well. Help appreciated, Thanks!
Solved by adam.nagy. Go to Solution.
Since you mentioned ThisDoc, I assume you are playing with iLogic.
I've written an article on this:
http://adndevblog.typepad.com/manufacturing/2014/07/list-sheet-names-in-ilogic-form.html
Cheers,
I appologize for the late reply. I have been on another project and have not had time to work on this. I never thought of launching a rule from a form. That seems like an effecient way to solve the problem. I will see what I can do to modify my existing code. I am thinking that only way to do this would be through check boxes in a form (attached). The main problem here being that a parameter would be required for each sheet, and the number of parameters would vary. This would mean a loop to remove all "sheet_#" boolean parameters would have to run, and then a loop to add back the new ones. Then the main problem would be coming up with code to update the form with the added/removed parameters. I am not sure if the later is even possible 😞
Here is my existing code, which is fairly basic but requires a lot of error handling and redirecting in order to be user friendly...
Dim oPath As String oPath = ThisDoc.Path Dim oFileName As String oFileName = ThisDoc.FileName(False) Dim oForProduction As String oForProduction = oPath & ("\_FOR PRODUCTION") 'PDF TARGET PATH Dim oPurchaseParts As String oPurchaseParts = oPath & ("\_PURCHASE PARTS") 'DXF TARGET PATH Dim PDFAddIn As TranslatorAddIn oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") Dim DXFAddIn As TranslatorAddIn oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium Dim oPDFName As String oPDFName = "\" & oFileName & (" ") & Left(DateString,2) & "." & Mid(DateString,4,2) & "." & Right(DateString,2) & ".pdf" Dim oDXFName As String oDXFName = "\" & oFileName & (" ") & Left(DateString,2) & "." & Mid(DateString,4,2) & "." & Right(DateString,2) & ".dxf" Dim MyArrayList As New ArrayList For Each s In ThisDoc.Document.Sheets MyArrayList.Add(s.Name) Next MultiValue.List("dxf_out") = MyArrayList If oFileName IsNot "" Then '[ _.PDF_ PDF_Start: oPDFExport = MessageBox.Show("Export " & oFileName & " to .pdf?", "Export To PDF", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question) If oPDFExport = vbYes Then If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If If Not System.IO.Directory.Exists(oForProduction) Then oFolderCreate = MessageBox.Show("Could not locate \_FOR PRODUCTION\ folder in this project." & vbLf & vbLf & "Create folder?", "Folder Not Found", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFolderCreate = vbYes Then System.IO.Directory.CreateDirectory(oForProduction) oDataMedium.FileName = oForProduction & oPDFName oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else oOverride = MessageBox.Show("\_FOR PRODUCTION\ unavailable." & vbLf & vbLf & "Continue export anyways?", "Confirm Export", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oOverride = vbYes Then If System.IO.File.Exists(ThisDoc.WorkspacePath() & oPDFName) Then oFileCheck = MessageBox.Show(ThisDoc.WorkspacePath() & oPDFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFileCheck = vbYes Then oDataMedium.FileName = ThisDoc.WorkspacePath() & oPDFName oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else MessageBox.Show("No .pdf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto PDF_Start End If Else oDataMedium.FileName = ThisDoc.WorkspacePath() & oPDFName oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If Else MessageBox.Show("No .pdf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto PDF_Start End If End If Else If System.IO.File.Exists(oForProduction & oPDFName) Then oFileCheck = MessageBox.Show(oForProduction & oPDFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFileCheck = vbYes Then oDataMedium.FileName = oForProduction & oPDFName oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else MessageBox.Show("No .pdf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto PDF_Start End If Else oDataMedium.FileName = oForProduction & oPDFName oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If End If ElseIf oPDFExport = vbNo Then MessageBox.Show("No .pdf files created.", "PDF Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Else MessageBox.Show("No files created.", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto iLogicEnd End If '] '[ _.DXF_ DXF_Start: oDXFExport = MessageBox.Show("Export " & oFileName & " to .dxf?", "Export To DXF", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If oDXFExport = vbYes Then If oDXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim oDXFConfig As String oDXFConfig = "G:\FSH_Engineering\ENGINEERING DRAWINGS\_UTILITY\dxf_export_config.ini" oOptions.Value("Export_Acad_IniFile") = DXFConfig End If If Not System.IO.Directory.Exists(oPurchaseParts) Then oFolderCreate = MessageBox.Show("Could not locate \_PURCHASE PARTS\ folder in this project." & vbLf & vbLf & "Create folder?", "Folder Not Found", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFolderCreate = vbYes Then System.IO.Directory.CreateDirectory(oPurchaseParts) oDataMedium.FileName = oPurchaseParts & oDXFName oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else oOverride = MessageBox.Show("\_PURCHASE PARTS\ unavailable." & vbLf & vbLf & "Continue export anyways?", "Confirm Export", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oOverride = vbYes Then If System.IO.File.Exists(ThisDoc.WorkspacePath() & oDXFName) Then oFileCheck = MessageBox.Show(ThisDoc.WorkspacePath() & oDXFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFileCheck = vbYes Then oDataMedium.FileName = ThisDoc.WorkspacePath() & oDXFName oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else MessageBox.Show("No .dxf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto DXF_Start End If Else oDataMedium.FileName = ThisDoc.WorkspacePath() & oDXFName oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If Else MessageBox.Show("No .dxf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto DXF_Start End If End If Else If System.IO.File.Exists(oPurchaseParts & oDXFName) Then oFileCheck = MessageBox.Show(oPurchaseParts & oDXFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation) If oFileCheck = vbYes Then oDataMedium.FileName = oPurchaseParts & oDXFName Call oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Else MessageBox.Show("No .dxf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Goto DXF_Start End If Else oDataMedium.FileName = oPurchaseParts & oDXFName Call oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If End If Else MessageBox.Show("No .dxf files created.", "DXF Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) End If '] Else MessageBox.Show("Save drawing before export.", "Failed To Export", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) End If iLogicEnd:
Try this one just change path where you want to save
oFileName = ThisDoc.FileName(False) 'without extension
'Define the drawing
DimoDrawingAsDrawingDocument
oDrawing = ThisDoc.Document
DimoSheetAsSheet
DimlPosAsLong
DimrPosAsLong
DimsLenAsLong
DimsSheetNameAsString
DimsSheetNumberAsInteger
'step through each drawing sheet
DimResponseAsMsgboxResult
ForEachoSheetInoDrawing.Sheets
Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
'''TRY
IfResponse = MsgBoxResult.YesThen
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos- 1)
'find the sheet numbe
sSheetNumber = Right(oSheet.Name, sLen-lPos)
EndIf
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
'get DXF target folder path
oFolder = "N:\"
'Set the DXF target file name
oDataMedium.FileName = oFolder&"\"&sSheetName&sSheetNumber&".dxf"
MessageBox.Show("DXF SAVED TO: "&oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
'Publish document
EndIf
'For
Next
Is there no way of combining multiple boolean response variables into one message box? I'm sure it's possible with a VB form, but my visual basic skills are poor. I have not been able to find a way to build an iLogic form from iLogic though, all of the information i've found so far has indicated iLogic forms are limited to manually adding parameters and rules.
I don't think iLogic provides that, but as you said, it's possible in other custom forms, like in a .NET form.
You could either create a separate .NET module and use that from iLogic, or just do the whole thing in a .NET AddIn.
