InputRadioBox for exporting DXF's
5 REPLIES 5
525 Views, 5 Replies
Does anyone know what the code for prompting a user to select which sheets to export as DXF's might entail? I think an input box with a populated radio group would be the best option here. Maybe a for loop adding 1 To ThisDoc.Document.Sheets.Count to a msgbox variable? Ideally it would remember This choice for the next time as well. Help appreciated, Thanks!
5 REPLIES 5
adam.nagy
Since you mentioned ThisDoc, I assume you are playing with iLogic.
I've written an article on this:
http://adndevblog.typepad.com/manufacturing/2014/07/list-sheet-names-in-ilogic-form.html
Cheers,
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
I appologize for the late reply. I have been on another project and have not had time to work on this. I never thought of launching a rule from a form. That seems like an effecient way to solve the problem. I will see what I can do to modify my existing code. I am thinking that only way to do this would be through check boxes in a form (attached). The main problem here being that a parameter would be required for each sheet, and the number of parameters would vary. This would mean a loop to remove all "sheet_#" boolean parameters would have to run, and then a loop to add back the new ones. Then the main problem would be coming up with code to update the form with the added/removed parameters. I am not sure if the later is even possible 😞
Here is my existing code, which is fairly basic but requires a lot of error handling and redirecting in order to be user friendly...
Dim oPath As String
oPath = ThisDoc.Path
Dim oFileName As String
oFileName = ThisDoc.FileName(False)
Dim oForProduction As String
oForProduction = oPath & ("\_FOR PRODUCTION") 'PDF TARGET PATH
Dim oPurchaseParts As String
oPurchaseParts = oPath & ("\_PURCHASE PARTS") 'DXF TARGET PATH
Dim PDFAddIn As TranslatorAddIn
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim DXFAddIn As TranslatorAddIn
oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oPDFName As String
oPDFName = "\" & oFileName & (" ") & Left(DateString,2) & "." & Mid(DateString,4,2) & "." & Right(DateString,2) & ".pdf"
Dim oDXFName As String
oDXFName = "\" & oFileName & (" ") & Left(DateString,2) & "." & Mid(DateString,4,2) & "." & Right(DateString,2) & ".dxf"
Dim MyArrayList As New ArrayList
For Each s In ThisDoc.Document.Sheets
	MyArrayList.Add(s.Name)
Next
MultiValue.List("dxf_out") = MyArrayList
If oFileName IsNot "" Then
	'[ _.PDF_
PDF_Start:
	oPDFExport = MessageBox.Show("Export " & oFileName & " to .pdf?", "Export To PDF", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question)
	If oPDFExport = vbYes Then
		If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
			oOptions.Value("All_Color_AS_Black") = 0
			oOptions.Value("Remove_Line_Weights") = 0
			oOptions.Value("Vector_Resolution") = 400
			oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
			'oOptions.Value("Custom_Begin_Sheet") = 2
			'oOptions.Value("Custom_End_Sheet") = 4
		End If
		If Not System.IO.Directory.Exists(oForProduction) Then
			oFolderCreate = MessageBox.Show("Could not locate \_FOR PRODUCTION\ folder in this project." & vbLf & vbLf & "Create folder?", "Folder Not Found", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
				If oFolderCreate = vbYes Then
					System.IO.Directory.CreateDirectory(oForProduction)
					oDataMedium.FileName = oForProduction & oPDFName
					oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
				Else
					oOverride = MessageBox.Show("\_FOR PRODUCTION\ unavailable." & vbLf & vbLf & "Continue export anyways?", "Confirm Export", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
						If oOverride = vbYes Then
							If System.IO.File.Exists(ThisDoc.WorkspacePath() & oPDFName) Then
								oFileCheck = MessageBox.Show(ThisDoc.WorkspacePath() & oPDFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
									If oFileCheck = vbYes Then
										oDataMedium.FileName = ThisDoc.WorkspacePath() & oPDFName
									Else
										MessageBox.Show("No .pdf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
										Goto PDF_Start
									End If
							Else
							End If
						Else
							Goto PDF_Start
						End If
				End If
		Else
				If System.IO.File.Exists(oForProduction & oPDFName) Then
				oFileCheck = MessageBox.Show(oForProduction & oPDFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
					Else
						Goto PDF_Start
					End If
				Else
				End If
		End If
	ElseIf oPDFExport = vbNo Then
		MessageBox.Show("No .pdf files created.", "PDF Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
	Else
		MessageBox.Show("No files created.", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
		Goto iLogicEnd
	End If
	'[ _.DXF_
DXF_Start:
	oDXFExport = MessageBox.Show("Export " & oFileName & " to .dxf?", "Export To DXF", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If oDXFExport = vbYes Then
			If oDXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
				Dim oDXFConfig As String
				oDXFConfig = "G:\FSH_Engineering\ENGINEERING DRAWINGS\_UTILITY\dxf_export_config.ini"
				oOptions.Value("Export_Acad_IniFile") = DXFConfig
			End If
		If Not System.IO.Directory.Exists(oPurchaseParts) Then
			oFolderCreate = MessageBox.Show("Could not locate \_PURCHASE PARTS\ folder in this project." & vbLf & vbLf & "Create folder?", "Folder Not Found", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
					System.IO.Directory.CreateDirectory(oPurchaseParts)
					oDataMedium.FileName = oPurchaseParts & oDXFName
					oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
				Else
					oOverride = MessageBox.Show("\_PURCHASE PARTS\ unavailable." & vbLf & vbLf & "Continue export anyways?", "Confirm Export", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
							If System.IO.File.Exists(ThisDoc.WorkspacePath() & oDXFName) Then
								oFileCheck = MessageBox.Show(ThisDoc.WorkspacePath() & oDXFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
										oDataMedium.FileName = ThisDoc.WorkspacePath() & oDXFName
									Else
										MessageBox.Show("No .dxf files created." & vbLf & "Returning...", "Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
										Goto DXF_Start
									End If
							Else
							End If
						Else
							Goto DXF_Start
						End If
				End If
		Else
			If System.IO.File.Exists(oPurchaseParts & oDXFName) Then
				oFileCheck = MessageBox.Show(oPurchaseParts & oDXFName & " already exists." & vbLf & vbLf & "Do you want to replace it?", "Confirm Save As", MessageBoxButtons.YesNo, MessageBoxIcon.Exclamation)
						Call oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
					Else
						Goto DXF_Start
					End If
			Else
			End If
		End If
	Else
		MessageBox.Show("No .dxf files created.", "DXF Export Aborted", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
	End If
Else
	MessageBox.Show("Save drawing before export.", "Failed To Export", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
End If
iLogicEnd:
GosponZ
Try this one just change path where you want to save
       oFileName = ThisDoc.FileName(False) 'without extension
        'Define the drawing
       DimoDrawingAsDrawingDocument
       oDrawing = ThisDoc.Document
       DimoSheetAsSheet
       DimlPosAsLong
       DimrPosAsLong
       DimsLenAsLong
       DimsSheetNameAsString
       DimsSheetNumberAsInteger
       'step through each drawing sheet
DimResponseAsMsgboxResult
ForEachoSheetInoDrawing.Sheets
           Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
'''TRY
           IfResponse = MsgBoxResult.YesThen
               'find the seperator in the sheet name:number
               lPos = InStr(oSheet.Name, ":")
               'find the number of characters in the sheet name
               sLen = Len(oSheet.Name)
               'find the sheet name
               sSheetName = Left(oSheet.Name, lPos- 1)
               'find the sheet numbe
           sSheetNumber = Right(oSheet.Name, sLen-lPos)
EndIf
ActiveSheet = ThisDrawing.Sheet(oSheet.Name)
               'get DXF target folder path
               oFolder = "N:\"
               'Set the DXF target file name
               oDataMedium.FileName = oFolder&"\"&sSheetName&sSheetNumber&".dxf"
               MessageBox.Show("DXF SAVED TO: "&oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
               'Publish document
           EndIf
                  'For
       Next
in reply to: GosponZ
Is there no way of combining multiple boolean response variables into one message box? I'm sure it's possible with a VB form, but my visual basic skills are poor. I have not been able to find a way to build an iLogic form from iLogic though, all of the information i've found so far has indicated iLogic forms are limited to manually adding parameters and rules.
adam.nagy
I don't think iLogic provides that, but as you said, it's possible in other custom forms, like in a .NET form.
You could either create a separate .NET module and use that from iLogic, or just do the whole thing in a .NET AddIn.
Adam Nagy
