Hi all,
I'm working on some iLogic code but it gives me an error
The strange thing is that the error apperase when i use the code as an External Rule.
When i copy the code to a Rule (local rule) the error does not appear.
In both rules the code works correct, but i like to use it as an External Rule, without the error.
I have made a User Parameter: "Keuze" that hase a Multivalue.
Hope you can help me,
Robert
Dim oPartDoc as PartDocument = ThisDoc.Document Dim userParams As UserParameters = oPartDoc.ComponentDefinition.Parameters.UserParameters Try Keuze_Params = oPartDoc.ComponentDefinition.Parameters("Keuze") Catch Dim newParam As UserParameter = userParams.AddByValue("Keuze", "", UnitsTypeEnum.kTextUnits) End Try MultiValue.List("Keuze") = GoExcel.CellValues("C:\temp\iLogic.xlsx", "Sheet1", "A2", "A6") Keuze= InputListBox("Huidige keuze: "& iProperties.Value("Project", "Description"), MultiValue.List("Keuze"), Keuze, Title := "Keuzelijst:", ListName := "Type keuze") If Keuze = Nothing Then Exit Sub LineNumber=GoExcel.FindRow("C:\temp\iLogic.xlsx", "Sheet1", "Naam", "=", Keuze) iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Code")
Solved by Carthik_Babu. Go to Solution.
Kindly assign "Test 1" instead of Keuze in your code....as shown below in your code...
Keuze= InputListBox("Huidige keuze: "& iProperties.Value("Project", "Description"), MultiValue.List("Keuze"), "Test 1", Title := "Keuzelijst:", ListName := "Type keuze")
